주요 콘텐츠로 건너뛰기
Shark Professional Steam Pocket Mop Open Mop Body Replacement
필요한 것
  1. Shark Professional Steam Pocket Mop  Open Mop Body Replacement, Shark Professional Steam Pocket Mop Front Panel Disassembly: 1 단계, 이미지 2개 중 1개 Shark Professional Steam Pocket Mop  Open Mop Body Replacement, Shark Professional Steam Pocket Mop Front Panel Disassembly: 1 단계, 이미지 2개 중 2개
    • Unwrap the power cord from the handle.
    • Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
    • Pull the handle to separate it from the body.
  2. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 2 단계, 이미지 3개 중 1개 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 2 단계, 이미지 3개 중 2개 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the three 12.0 mm Phillips head #2 screws where the handle connects to the body.
    • Remove the plastic cap.
  3. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 3 단계, 이미지 2개 중 1개 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the three 16.0 mm T10 Torx screws near the top of the body and remove the water tank cap.
    • The third screw is directly on other side of the bottom screw in the photo.
  4. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 4 단계, 이미지 3개 중 1개 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 4 단계, 이미지 3개 중 2개 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 4 단계, 이미지 3개 중 3개
    • Remove steam control button cover with a metal spudger.
    • Remove the two 12.0 mm Phillips head #2 screws underneath.
    • Remove the plastic rim with clear plastic cover.
  5. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 5 단계, 이미지 3개 중 1개 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 5 단계, 이미지 3개 중 2개 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the Shark logo decal on the front of body using a metal spudger.
    • Pull out the plastic cover to remove.
  6. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 6 단계, 이미지 1개 중 1개
    • Pop off the grey front plate to expose the control panel and screws necessary to open mop body.
  7. Shark Professional Steam Pocket Mop  Open Mop Body Replacement, Shark Professional Steam Pocket Mop Open Mop Body: 7 단계, 이미지 1개 중 1개
    • Remove the three 12.0 mm Philips head #2 screws connected to the dark grey plastic trim.
  8. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the four 16.0 mm T10 Torx screws located on the back of the mop.
  9. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the two 12.0 mm Phillips head #2 screws that hold the power cord to the device.
  10. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 10 단계, 이미지 1개 중 1개
    • Pop off the dark grey plastic trim cover.
  11. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 11 단계, 이미지 1개 중 1개
    • Pop open the white plastic mop body by pulling apart from the front and back side.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Brett Wilson
회원 가입일: 02/12/18
1,019 평판
안내서 6개를 작성함
USF Tampa, Team S15-G1, Boczar Spring 2018 USF Tampa, Team S15-G1, Boczar Spring 2018 회원
USFT-BOCZAR-S18S15G1
4 회원들
안내서 14개를 작성함
1가이드 댓글
good afternoon, i need the water pump for that shark steamer. my model is S3601A.
Thank you.
Eduardo - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 16
지난 30일: 54
전체 시간: 6,264
