주요 콘텐츠로 건너뛰기
Shark Professional Steam Pocket Mop Control Panel Replacement
필요한 것
  1. Shark Professional Steam Pocket Mop Control Panel Replacement, Shark Professional Steam Pocket Mop Front Panel Disassembly: 1 단계, 이미지 2개 중 1개 Shark Professional Steam Pocket Mop Control Panel Replacement, Shark Professional Steam Pocket Mop Front Panel Disassembly: 1 단계, 이미지 2개 중 2개
    • Unwrap the power cord from the handle.
    • Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
    • Pull the handle to separate it from the body.
  2. Shark Professional Steam Pocket Mop Control Panel Replacement: 2 단계, 이미지 3개 중 1개 Shark Professional Steam Pocket Mop Control Panel Replacement: 2 단계, 이미지 3개 중 2개 Shark Professional Steam Pocket Mop Control Panel Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the three 12.0 mm Phillips head #2 screws where the handle connects to the body.
    • Remove the plastic cap.
  3. Shark Professional Steam Pocket Mop Control Panel Replacement: 3 단계, 이미지 2개 중 1개 Shark Professional Steam Pocket Mop Control Panel Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the three 16.0 mm T10 Torx screws near the top of the body and remove the water tank cap.
    • The third screw is directly on other side of the bottom screw in the photo.
  4. Shark Professional Steam Pocket Mop Control Panel Replacement: 4 단계, 이미지 3개 중 1개 Shark Professional Steam Pocket Mop Control Panel Replacement: 4 단계, 이미지 3개 중 2개 Shark Professional Steam Pocket Mop Control Panel Replacement: 4 단계, 이미지 3개 중 3개
    • Remove steam control button cover with a metal spudger.
    • Remove the two 12.0 mm Phillips head #2 screws underneath.
    • Remove the plastic rim with clear plastic cover.
  5. Shark Professional Steam Pocket Mop Control Panel Replacement: 5 단계, 이미지 3개 중 1개 Shark Professional Steam Pocket Mop Control Panel Replacement: 5 단계, 이미지 3개 중 2개 Shark Professional Steam Pocket Mop Control Panel Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the Shark logo decal on the front of body using a metal spudger.
    • Pull out the plastic cover to remove.
  6. Shark Professional Steam Pocket Mop Control Panel Replacement: 6 단계, 이미지 1개 중 1개
    • Pop off the grey front plate to expose the control panel and screws necessary to open mop body.
  7. Shark Professional Steam Pocket Mop Control Panel Replacement, Control Panel: 7 단계, 이미지 2개 중 1개 Shark Professional Steam Pocket Mop Control Panel Replacement, Control Panel: 7 단계, 이미지 2개 중 2개
    • Remove the two 12.0 mm Phillips head #2 screws. Disconnect the control board.
    • Disconnect the control board
결론
작성자
2다른 기여자 명과 함께
Brett Wilson
회원 가입일: 02/12/18
1,019 평판
안내서 6개를 작성함
USF Tampa, Team S15-G1, Boczar Spring 2018 USF Tampa, Team S15-G1, Boczar Spring 2018 회원
USFT-BOCZAR-S18S15G1
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 898
