주요 콘텐츠로 건너뛰기
Shark Professional Steam Pocket Mop Steam Nozzle Replacement
필요한 것
  1. Shark Professional Steam Pocket Mop Steam Nozzle Replacement, Steam Nozzle: 1 단계, 이미지 1개 중 1개
    • Press the mop head release button to remove it from the steam mop body.
  2. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 10mm screws holding the joint assembly to the mop head with your Phillips #2 screwdriver.
  3. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two plastic hinge covers by pulling the hinges out of the joint and sliding the covers off.
  4. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 4 단계, 이미지 1개 중 1개
    • Stretch joint assembly forward to expose two 11mm Phillips #2 screws on either side of the steam tube.
    • Remove both screws.
  5. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 5 단계, 이미지 1개 중 1개
    • Lift joint assembly out of hinge socket and pull upward with mild force to disconnect steam nozzle.
  6. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 6 단계, 이미지 1개 중 1개
    • Use needle nose pliers to compress metal clamp .
  7. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the nozzle out of the tube.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Michael Raymond
회원 가입일: 02/12/18
154 평판
안내서 1개를 작성함
USF Tampa, Team S15-G1, Boczar Spring 2018 USF Tampa, Team S15-G1, Boczar Spring 2018 회원
USFT-BOCZAR-S18S15G1
4 회원들
안내서 14개를 작성함
2가이드 댓글
This was fantastic. Only place I found on how to disassemble mop head. If i were you, I would go a little further and explain how to clean the nozzle. Use a paper clip or 20 gauge wire to push build up out. If that does not work use a small drill bit ( be careful to drill straight or you could damage the wall or jacket . This worked for me. Saved me $30. Had a problem locating this sight. Maybe some way to make it easier to locate would help. Thanks for your posting.
Mike Cunningham - 답글
Do you know if I can soak this part in clr? I can't seem to clean it well enough.
Kelsey Harper -
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 65
전체 시간: 6,179
