주요 콘텐츠로 건너뛰기
Shark Professional Steam Pocket Mop Water Tank Cap Replacement
  1. Shark Professional Steam Pocket Mop Water Tank Cap Replacement, Water Tank Cap: 1 단계, 이미지 1/2 Shark Professional Steam Pocket Mop Water Tank Cap Replacement, Water Tank Cap: 1 단계, 이미지 2/2
    • Turn off the Steam Pocket Mop and unplug it from the wall.
    • Be sure that the water in the water tank cools to room temperature before proceeding.
  2. Shark Professional Steam Pocket Mop Water Tank Cap Replacement: 2 단계, 이미지 1/3 Shark Professional Steam Pocket Mop Water Tank Cap Replacement: 2 단계, 이미지 2/3 Shark Professional Steam Pocket Mop Water Tank Cap Replacement: 2 단계, 이미지 3/3
    • Remove the water tank cap from the water tank reservoir.
    • Turn the cap towards the upward position.
    • Rotate counter-clockwise until it loosens.
    • When reassembling, align the grooves of new water tank cap with the opening of water tank reservoir and then push in.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tyler Wicke
회원 가입일: 10/17/18
237 평판
안내서 2개 작성하였습니다
UW Tacoma, Team S1-G3, Rose Fall 2018 UW Tacoma, Team S1-G3, Rose Fall 2018 회원
UWT-ROSE-F18S1G3
4 회원들
안내서 10개 작성하였습니다
댓글 12개
Need a water cap for S3901 N3 11 Shark steam mop. They said they discontinued and I have ordered two online and neither will work. And I really going to have to buy a new one?
shannon poole - 답글
Same here did you come across one
carl yardley -
Did you find any place that sold these caps? I’m in the same boat need a new water cap.
Rick -
hola a mi trapeador shark lift away no le sale vapor y es nuevo tendra algun defecto?
Eveliza Higuera - 답글
Any updates on getting this part
bryn.rees - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 48
전체 시간: 9,615
