소개
The hose of the Shark Rocket HV301 may need to be replaced if a hole has been worn into it. This can cause weak suction and for your vacuum to not operate properly. If this is the case, follow this guide to replace the hose on your HV301. This guide may also be used to disconnect your hose to remove a blockage.
필요한 것
Gently pinch head of cable and pull upwards until upper casing disconnects from vacuum and proceed with removing upper casing.
Return the vacuum to its original position with the roller brush facing you.
Locate the screw to the right of the vacuum hose, close to the right wheel, and remove the screw with a Phillips #2 screwdriver.
다른 32명이 해당 안내서를 완성하였습니다.
56 댓글
Great instructions, now where do I get the replacement hose. I can't seem to find one anywhere, please tell be where to look
Kay Fisher - 답글
Rob the hose from the hard floor attachment, you probably do not use it as at low speed the brush head is awesome on hard floors.
I found a hose that is a perfect fit. EVERBILT 6 ft Bilge and Pump Discharge Hose. 1-1/8 inch ID. Got it at Home Depot.
How did you get the hose from Home Depot to work? I’d like to try it, and I was hoping you would give some advice.
Thank you so much for this recommendation! The Everbilt Bilge and Pump hose works perfectly!!! And now I have back up if I need to replace it again.
Thank you for the instructions as well Shelby! So much better than spending another $50 on a replacement head!
