주요 콘텐츠로 건너뛰기
Shark Rocket HV301 Rotary Belt Replacement
필요한 것
  1. Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: 1 단계, 이미지 1/3 Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: 1 단계, 이미지 2/3 Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: 1 단계, 이미지 3/3
    • Flip the vacuum so the bottom base is visible.
    • Gently pry the bottom two wheels off with a plastic opening tool.
    I don’t know why these companies use a screw that most people don’t have around the house to fit it.
    These are in st tight it snaps when it finally turns.
    I can’t even use mine now that I have to go out and buy this tool and I have a lot of tool. Not this one. Come on guys.
    robincharest@icloud.com - 답글
  2. Shark Rocket HV301 Rotary Belt Replacement: 2 단계, 이미지 1/3 Shark Rocket HV301 Rotary Belt Replacement: 2 단계, 이미지 2/3 Shark Rocket HV301 Rotary Belt Replacement: 2 단계, 이미지 3/3
    • Remove five visible screws with a Phillips #2 screwdriver.
    • Locate and twist the three plastic screws to the unlock position with a quarter or flathead screwdriver.
    They don't have Phillip's screw heads. They have Star head size T15
    Matthew Heddle - 답글
    Yes, mine are not PH2 but star 15, my problem is I cannot reach two of the screws that are so deep into the molding of the plastic, I cannot get my star T15 in there. Now what?
    Nunya -
    Mine had Phillips on all the steps.
    Martin Garcia - 답글
    I have been so happy with my Shark until NOW.
    Nunya - 답글
  3. Shark Rocket HV301 Rotary Belt Replacement: 3 단계, 이미지 1/3 Shark Rocket HV301 Rotary Belt Replacement: 3 단계, 이미지 2/3 Shark Rocket HV301 Rotary Belt Replacement: 3 단계, 이미지 3/3
    • Remove plate covering the roller brush.
  4. Shark Rocket HV301 Rotary Belt Replacement: 4 단계, 이미지 1/2 Shark Rocket HV301 Rotary Belt Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #2 screwdriver to extract the three screws revealed from removing the plate.
    Not Phillips. It’s a Torx 15 security head.
    Matthew Heddle - 답글
  5. Shark Rocket HV301 Rotary Belt Replacement: 5 단계, 이미지 1/3 Shark Rocket HV301 Rotary Belt Replacement: 5 단계, 이미지 2/3 Shark Rocket HV301 Rotary Belt Replacement: 5 단계, 이미지 3/3
    • Turn the vacuum over so the rotary brush is on the ground.
    • Grab the vacuum on both sides of the hose and pull up to remove the top of the vacuum halfway.
    What if it's stuck on one side I don't want to break
    Amanda - 답글
    Mine is not opening as wide as the one pictured here; very difficult to get my fingers in enough to grip. Any suggestions?
    debi stanton - 답글
    Did anyone find away to get it unstuck/ to open
    Juanita - 답글
    Wish mine came off that easily. I'm afraid if I pull up any harder, it will break.
    Ann Ervin - 답글
    I thought I broke plastic two or three times when prying stuff apart, but everything seemed intact and snapped back into place OK. Some wires kept trying to poke out by one of the wheels, though.
    Paully Wally Doodle - 답글
    A note to Reassembly- be very careful that the 3 wires coming out by the right wheel are tucked into the protective guide hole on the wand end.(1/2" circular hole with slit for wires) Then when you seat the assembly in the body they're not pinching and still in the guide hole.
    I had to do a repair because I had previously not paid attention to the wires and the power wire pinched apart.
    hollis - 답글
  6. Shark Rocket HV301 Rotary Belt Replacement: 6 단계, 이미지 1/2 Shark Rocket HV301 Rotary Belt Replacement: 6 단계, 이미지 2/2
    • Gently pinch the head of the cable and pull upwards until the casing disconnects from the vacuum.
    • Proceed with removing the upper casing.
    I need the hose that’s in the middle of wheels
    Diane Phelps - 답글
  7. Shark Rocket HV301 Rotary Belt Replacement: 7 단계, 이미지 1/2 Shark Rocket HV301 Rotary Belt Replacement: 7 단계, 이미지 2/2
    • Use a Phillips #2 screwdriver to remove the four visible screws securing the rotary brush to the vacuum.
    Torx 15 security, not Phillips
    Matthew Heddle - 답글
    My shark same model as this the screws definitely aren’t a Phillips head. I tried all them * star screwdrivers Allen wrench I can’t get them off. Please help.
  8. Shark Rocket HV301 Rotary Belt Replacement: 8 단계, 이미지 1/3 Shark Rocket HV301 Rotary Belt Replacement: 8 단계, 이미지 2/3 Shark Rocket HV301 Rotary Belt Replacement: 8 단계, 이미지 3/3
    • Remove the rotary belt on right side of vacuum from the bearing.
    • Gently lift the casing to remove the belt and brush from the vacuum.
    Did everything as instructed, putting it back together I'm having a difficult time getting the plastic housing back because of a little white piece that's on the motor. Any suggestions?
    Willow - 답글
    Remove the two motor mounting screws. Rotate the motor out of the way
    Ronald Simmons -
    The worst just to get the roller brush out for a good cleaning! My experience of taking out these brushes is over 30 years. I have removed my vacuums brush roller at least once a month to clean. Totally not acceptable won't buy another Shark!
    Simply Raw - 답글
    Can I remove the roller brush altogether and use the vacuum for suction alone? My wool rugs should not be vacuumed with a beater bar, only suction. Thanks!
    Angela Grammatico - 답글
  9. Shark Rocket HV301 Rotary Belt Replacement: 9 단계, 이미지 1/3 Shark Rocket HV301 Rotary Belt Replacement: 9 단계, 이미지 2/3 Shark Rocket HV301 Rotary Belt Replacement: 9 단계, 이미지 3/3
    • Gently pry off the plastic casing on both sides of rotary brush.
    • Lift the clear plastic shell from the rotary brush.
    This is very difficult to
    Samia - 답글
  10. Shark Rocket HV301 Rotary Belt Replacement: 10 단계, 이미지 1/1
    • Remove the rotary belt attached to the brush and replace it if needed.
    What model are these specific brushroll
    Albert Einstein - 답글
    I did all that and had no problem. Due to rug fibers that were lodged in the plastic casing, the plastic itself deteriorates overtime. After cleaning the brush and the plastic casing on both sides it became loose and won’t hold or stay to hold the brush anymore. Where can I order those plastic casing?
    Please help me.
    Thank you
    Andres
    Andres B - 답글
    Shark Rocket HV301 model
    Andres B - 답글
    THE worst! I've taken rollers out for over 30 yrs once a month to clean them. Should be super easy and not so many steps to do this. I won't buy another Shark this is not acceptable
    Simply Raw - 답글
    Directions really helped. Thanks so much. Definitely not user friendly roller or belt replacement. Vacuum engineers apparently wanted suction performance over ease of roller and belt replacement. Either that or they are into schadenfreude! 😀 Vacuum works great, so worth the ordeal.
    ronboone@comcast.net - 답글
  11. Shark Rocket HV301 Rotary Belt Replacement, Rotary Belt: 11 단계, 이미지 1/1
    • Replace belt if torn or damaged.
    What size belt will work in a Shark Rocket Delux?
    Emily - 답글
    What a hassle for a $18 part! Took me over an hour as I was checking the size of each screw as I took them out and then had a left over one when I was done and had to disassemble ity again to find the one I missed,.
    Tim Mullins - 답글
결론
다른 15명이 해당 안내서를 완성하였습니다.
Trey Nahhas
회원 가입일: 10/06/16
776 평판
안내서 1개 작성함
Cal Poly, Team 10-5, Livingston Fall 2016 Cal Poly, Team 10-5, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G5
4 회원들
안내서 14개 작성하였습니다
댓글 3개
Where can I find the rotary belt for the Shark Duo?
oneupchallenges - 답글
I could not get it out without removing the brush roll motor. So I am putting it back together and I need to know if the motor has a top and bottom. What I mean is does it matter ? Thank you
Jennifer Dalton - 답글
Thanks for the guide it came in super handy
SYSTEM 855 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 45
30일 전: 222
전체 시간: 33,313
