주요 콘텐츠로 건너뛰기
Shark Rocket HV381 LED Replacement
필요한 것
  1. Shark Rocket HV381 LED Replacement, Roller: 1 단계, 이미지 1/2 Shark Rocket HV381 LED Replacement, Roller: 1 단계, 이미지 2/2
    • On the right-bottom of the body, pull down the black switch. You will hear an audible click when you detach the body from the vacuum head.
  2. Shark Rocket HV381 LED Replacement: 2 단계, 이미지 1/1
    • Laying the vacuum head on the its right side, push the orange "Eject Roller" switch down. The Roller can now be removed with ease.
  3. Shark Rocket HV381 LED Replacement, LED: 3 단계, 이미지 1/2 Shark Rocket HV381 LED Replacement, LED: 3 단계, 이미지 2/2
    • On the back of the vacuum head, located near the bottom, should be a row of screws. Using the T15 Screwdriver, remove all the screws on the bottom and the sides.
  4. Shark Rocket HV381 LED Replacement: 4 단계, 이미지 1/1
    • On the top side of the vacuum head, where the LED is located, use the Small Flathead screwdriver to pry open the cover. There should be no resistance.
  5. Shark Rocket HV381 LED Replacement: 5 단계, 이미지 1/3 Shark Rocket HV381 LED Replacement: 5 단계, 이미지 2/3 Shark Rocket HV381 LED Replacement: 5 단계, 이미지 3/3
    • Picking the LED from the side, pull upwards to unwind the wires from their tracks.
    • Make sure that you are gentle because the wires are very fragile. One strong pull could easily snap them from the LED.
결론
Dandre Porter
회원 가입일: 08/22/17
528 평판
안내서 5개 작성하였습니다
Arkansas State University, Team S1-G5, Chamberlain Fall 2017 Arkansas State University, Team S1-G5, Chamberlain Fall 2017 회원
ARSU-CHAMBERLAIN-F17S1G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 444
