주요 콘텐츠로 건너뛰기
Shark Rocket Powerhead AH401 Brushroll Replacement
  1. Shark Rocket Powerhead AH401 Brushroll Replacement, Brushroll: 1 단계, 이미지 1/3 Shark Rocket Powerhead AH401 Brushroll Replacement, Brushroll: 1 단계, 이미지 2/3 Shark Rocket Powerhead AH401 Brushroll Replacement, Brushroll: 1 단계, 이미지 3/3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Brushroll Replacement: 2 단계, 이미지 1/2 Shark Rocket Powerhead AH401 Brushroll Replacement: 2 단계, 이미지 2/2
    • Lift the brushroll out by pulling the tab labeled "pull".
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Toan Pham
회원 가입일: 01/24/18
269 평판
안내서 3개 작성하였습니다
Cal Poly, Team S19-G3, Livingston Winter 2018 Cal Poly, Team S19-G3, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S19G3
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
Can we still get filters (foam & Cotton) for a AH452 Shark, Rocket Powerhead Vacuum?
Olive August - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 17
전체 시간: 914
