주요 콘텐츠로 건너뛰기
Shark Rocket Powerhead AH401 Filter Grille Replacement
필요한 것
  1. Shark Rocket Powerhead AH401 Filter Grille Replacement, Dust Cup: 1 단계, 이미지 1/3 Shark Rocket Powerhead AH401 Filter Grille Replacement, Dust Cup: 1 단계, 이미지 2/3 Shark Rocket Powerhead AH401 Filter Grille Replacement, Dust Cup: 1 단계, 이미지 3/3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  2. Shark Rocket Powerhead AH401 Filter Grille Replacement: 2 단계, 이미지 1/2 Shark Rocket Powerhead AH401 Filter Grille Replacement: 2 단계, 이미지 2/2
    • Remove the dust cup by lifting it off the dock.
  3. Shark Rocket Powerhead AH401 Filter Grille Replacement, Filter Grille: 3 단계, 이미지 1/2 Shark Rocket Powerhead AH401 Filter Grille Replacement, Filter Grille: 3 단계, 이미지 2/2
    • Push inward on the top of the filter grille where it says "Push."
    • Lift the filter grille upward.
  4. Shark Rocket Powerhead AH401 Filter Grille Replacement: 4 단계, 이미지 1/2 Shark Rocket Powerhead AH401 Filter Grille Replacement: 4 단계, 이미지 2/2
    • Lift gently and pull the grille up towards you until it releases.
    • The post-motor filter is underneath the filter grille.
결론
Shobhit Dabral
회원 가입일: 01/24/18
913 평판
안내서 6개 작성하였습니다
Cal Poly, Team S19-G3, Livingston Winter 2018 Cal Poly, Team S19-G3, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S19G3
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 312
