주요 콘텐츠로 건너뛰기
Shark Rocket Powerhead AH401 Motherboard Replacement
필요한 것
  1. Shark Rocket Powerhead AH401 Motherboard Replacement, Brushroll: 1 단계, 이미지 3개 중 1개 Shark Rocket Powerhead AH401 Motherboard Replacement, Brushroll: 1 단계, 이미지 3개 중 2개 Shark Rocket Powerhead AH401 Motherboard Replacement, Brushroll: 1 단계, 이미지 3개 중 3개
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Motherboard Replacement, Dust Cup: 3 단계, 이미지 3개 중 1개 Shark Rocket Powerhead AH401 Motherboard Replacement, Dust Cup: 3 단계, 이미지 3개 중 2개 Shark Rocket Powerhead AH401 Motherboard Replacement, Dust Cup: 3 단계, 이미지 3개 중 3개
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  4. Shark Rocket Powerhead AH401 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the dust cup by lifting it off the dock.
  5. Shark Rocket Powerhead AH401 Motherboard Replacement, Back Panel Screws: 5 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motherboard Replacement, Back Panel Screws: 5 단계, 이미지 2개 중 2개
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
  6. Shark Rocket Powerhead AH401 Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 1개 Shark Rocket Powerhead AH401 Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 2개 Shark Rocket Powerhead AH401 Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 3개
    • Remove the three 10mm screws by rotating counter clockwise with a T15 Torx screwdriver.
    • Remove the airpath grille by gently lifting up and away from the motor compartment.
  7. Shark Rocket Powerhead AH401 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove two 14mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
  8. Shark Rocket Powerhead AH401 Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Shark Rocket Powerhead AH401 Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Shark Rocket Powerhead AH401 Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Lift and gently remove the hinge compartment covering the motherboard.
  9. Shark Rocket Powerhead AH401 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the two 10mm screws by rotating counter-clockwise with a T10 Torx screwdriver
  10. Shark Rocket Powerhead AH401 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Lift the motherboard out of its compartment.
  11. Shark Rocket Powerhead AH401 Motherboard Replacement: 11 단계, 이미지 3개 중 1개 Shark Rocket Powerhead AH401 Motherboard Replacement: 11 단계, 이미지 3개 중 2개 Shark Rocket Powerhead AH401 Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    • Locate and remove these connections by pulling the plugs out of the sockets.
  12. Shark Rocket Powerhead AH401 Motherboard Replacement: 12 단계, 이미지 3개 중 1개 Shark Rocket Powerhead AH401 Motherboard Replacement: 12 단계, 이미지 3개 중 2개 Shark Rocket Powerhead AH401 Motherboard Replacement: 12 단계, 이미지 3개 중 3개
    • Flip the motherboard over to reveal the wires underneath.
    • Locate and cut all the wires connected to the motherboard using cutting pliers.
결론
작성자
4다른 기여자 명과 함께
Shobhit Dabral
회원 가입일: 01/24/18
913 평판
안내서 6개를 작성함
Cal Poly, Team S19-G3, Livingston Winter 2018 Cal Poly, Team S19-G3, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S19G3
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 655
