주요 콘텐츠로 건너뛰기
Shark Rocket Powerhead AH401 Motor Replacement
필요한 것
  1. Shark Rocket Powerhead AH401 Motor Replacement, Brushroll: 1 단계, 이미지 3개 중 1개 Shark Rocket Powerhead AH401 Motor Replacement, Brushroll: 1 단계, 이미지 3개 중 2개 Shark Rocket Powerhead AH401 Motor Replacement, Brushroll: 1 단계, 이미지 3개 중 3개
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Motor Replacement: 2 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motor Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Motor Replacement, Back Panel Screws: 3 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motor Replacement, Back Panel Screws: 3 단계, 이미지 2개 중 2개
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
  4. Shark Rocket Powerhead AH401 Motor Replacement, Filter Grille: 4 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motor Replacement, Filter Grille: 4 단계, 이미지 2개 중 2개
    • Push inward on the top of the filter grille where it says "Push."
    • Lift the filter grille upward.
  5. Shark Rocket Powerhead AH401 Motor Replacement: 5 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motor Replacement: 5 단계, 이미지 2개 중 2개
    • Lift gently and pull the grille up towards you until it releases.
    • The post-motor filter is underneath the filter grille.
  6. Shark Rocket Powerhead AH401 Motor Replacement, Belt: 6 단계, 이미지 1개 중 1개
    • Remove the four screws by rotating counter-clockwise:
    • One 12 mm screw with a T10 Torx screwdriver
    • Three 14 mm screw with a T15 Torx screwdriver
  7. Shark Rocket Powerhead AH401 Motor Replacement: 7 단계, 이미지 3개 중 1개 Shark Rocket Powerhead AH401 Motor Replacement: 7 단계, 이미지 3개 중 2개 Shark Rocket Powerhead AH401 Motor Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the grey filter plate by simply lifting upward.
    • Remove the 14mm screw by rotating counter clockwise with a T10 Torx screwdriver.
  8. Shark Rocket Powerhead AH401 Motor Replacement: 8 단계, 이미지 1개 중 1개
    • Remove three 10mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
  9. Shark Rocket Powerhead AH401 Motor Replacement: 9 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motor Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the airpath grille from the side of the motor compartment by pulling out and away from the attached area.
  10. Shark Rocket Powerhead AH401 Motor Replacement: 10 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motor Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the motor compartment panel by lifting up and away from the device.
  11. Shark Rocket Powerhead AH401 Motor Replacement: 11 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motor Replacement: 11 단계, 이미지 2개 중 2개
    • Remove one 14mm screw by rotating counter-clockwise with a T15 Torx screwdriver.
  12. Shark Rocket Powerhead AH401 Motor Replacement: 12 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motor Replacement: 12 단계, 이미지 2개 중 2개
    • Disconnect the motor side panel by lifting the motor and panel up and out.
    • This step may require some wiggling to loosen the panel before it becomes free.
  13. Shark Rocket Powerhead AH401 Motor Replacement: 13 단계, 이미지 1개 중 1개
    • Remove one 9mm screw by rotating counter-clockwise with a Phillips #2 screwdriver.
    • This screw allows the side panel to be removed.
  14. Shark Rocket Powerhead AH401 Motor Replacement: 14 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motor Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the side panel by pulling the panel out and away from the motor.
    • The side panel is connected with clips which connect near the brushroll axle.
  15. Shark Rocket Powerhead AH401 Motor Replacement: 15 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motor Replacement: 15 단계, 이미지 2개 중 2개
    • Loosen the two screws by rotating counter clockwise with a T15 Torx screwdriver.
    • The screws only need to be loosened in order to free the belt.
  16. Shark Rocket Powerhead AH401 Motor Replacement: 16 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motor Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the belt by pulling the belt away from the axle.
  17. Shark Rocket Powerhead AH401 Motor Replacement, Motor: 17 단계, 이미지 1개 중 1개
    • Remove two 16mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
  18. Shark Rocket Powerhead AH401 Motor Replacement: 18 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motor Replacement: 18 단계, 이미지 2개 중 2개
    • Remove the belt-assembly unit by pulling the belt-assembly unit away from the motor.
  19. Shark Rocket Powerhead AH401 Motor Replacement: 19 단계, 이미지 2개 중 1개 Shark Rocket Powerhead AH401 Motor Replacement: 19 단계, 이미지 2개 중 2개
    • Rotate the motor unit over so that the wires are exposed.
    • Cut wires with cutting pliers to release the motor.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Shobhit Dabral
회원 가입일: 01/24/18
913 평판
안내서 6개를 작성함
Cal Poly, Team S19-G3, Livingston Winter 2018 Cal Poly, Team S19-G3, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S19G3
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 30
전체 시간: 4,445
