주요 콘텐츠로 건너뛰기
Shark Rocket Powerhead AH401 Panel Screws Replacement
필요한 것
  1. Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: 1 단계, 이미지 1/3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: 1 단계, 이미지 2/3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: 1 단계, 이미지 3/3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Panel Screws Replacement: 2 단계, 이미지 1/2 Shark Rocket Powerhead AH401 Panel Screws Replacement: 2 단계, 이미지 2/2
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: 3 단계, 이미지 1/3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: 3 단계, 이미지 2/3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: 3 단계, 이미지 3/3
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  4. Shark Rocket Powerhead AH401 Panel Screws Replacement: 4 단계, 이미지 1/2 Shark Rocket Powerhead AH401 Panel Screws Replacement: 4 단계, 이미지 2/2
    • Remove the dust cup by lifting it off the dock.
  5. Shark Rocket Powerhead AH401 Panel Screws Replacement, Back Panel Screws: 5 단계, 이미지 1/2 Shark Rocket Powerhead AH401 Panel Screws Replacement, Back Panel Screws: 5 단계, 이미지 2/2
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
결론
Toan Pham
회원 가입일: 01/24/18
269 평판
안내서 3개 작성하였습니다
Cal Poly, Team S19-G3, Livingston Winter 2018 Cal Poly, Team S19-G3, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S19G3
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 20
전체 시간: 939
