주요 콘텐츠로 건너뛰기
Shark Rocket Professional Floor Hose Replacement
필요한 것
  1. Shark Rocket Professional Floor Hose Replacement, Floor Hose: 1 단계, 이미지 1/2 Shark Rocket Professional Floor Hose Replacement, Floor Hose: 1 단계, 이미지 2/2
    • Look at the side of your vacuum.
    • Identify the button that says "Floor Nozzle."
    • Press this button and remove the main body of the vacuum.
  2. Shark Rocket Professional Floor Hose Replacement: 2 단계, 이미지 1/3 Shark Rocket Professional Floor Hose Replacement: 2 단계, 이미지 2/3 Shark Rocket Professional Floor Hose Replacement: 2 단계, 이미지 3/3
    • Look at the bottom of the Floor Nozzle.
    • Use a coin to turn the orange locking dials counter-clockwise.
    • If you are unsure, follow the arrows when turning the orange dials because the labeling is confusing.
  3. Shark Rocket Professional Floor Hose Replacement: 3 단계, 이미지 1/1
    • Use your fingers to pull open the panel locked by the orange mechanism.
    • If there is debris stuck in the tube, use a long, thin object to remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brad Iglesia
회원 가입일: 01/24/18
316 평판
안내서 2개 작성하였습니다
Cal Poly, Team S18-G6, Livingston Winter 2018 Cal Poly, Team S18-G6, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S18G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 38
전체 시간: 4,858
