소개
Does your vacuum fail to pick up particles on your floor? If so, this guide outlines how to remove the two vacuum tubes on the Shark Rocket Professional. While reading this guide, you will also learn how to unclog your vacuum to improve suction.
필요한 것
Look at the Shark Rocket Professional's Extension Rod.
Identify where the hose connects to the main body of the vacuum.
Press the tabs on the sides of the connector to remove the hose.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 4개
How about an expla8nation about how t9 actually do the lower the hose inside the brush head
How do you replace the hose in the beater head
daveve2 -
Thank you for this, this guide helped a ton.
