소개
Before completing this guide, it's important to know how to remove the dust cap. If you are unsure how to do so, the dust cap guide is shown below to help you out.
First, locate the button that says "Dust Cup". It is right next to the power button at the base of the handle.
Press the button down completely; you should feel a click.
As you look beneath the base of the dust cup, you will see a white foam filter. Remove this filter with your fingers.
다른 한 분이 해당 안내서를 완성하였습니다.
