소개
The vacuum belt keeps the brushroll spinning properly. If your brushroll is not spinning or is spinning irregularly, you may need to check the placement and/or quality of the belt. This guide will show you how to access and remove the belt.
필요한 것
Locate the release button at the top of the vacuum pod next to the handle.
Use the handle to lift the pod up off of the vacuum nozzle while pressing the release button.
다른 4명이 해당 안내서를 완성하였습니다.
