주요 콘텐츠로 건너뛰기
소개
The vacuum belt keeps the brushroll spinning properly. If your brushroll is not spinning or is spinning irregularly, you may need to check the placement and/or quality of the belt. This guide will show you how to access and remove the belt.
  1. Make sure the vacuum is turned off and unplugged before proceeding.
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Locate the release button at the top of the vacuum pod next to the handle.
    • Use the handle to lift the pod up off of the vacuum nozzle while pressing the release button.
    • Removing the pod is optional, but it may be easier to locate blockages or access the motor and belt if you do so.
  2. Press the Brushroll Access buttons on the top of the nozzle to reveal the brushroll compartment. Press the Brushroll Access buttons on the top of the nozzle to reveal the brushroll compartment.
    • Press the Brushroll Access buttons on the top of the nozzle to reveal the brushroll compartment.
  3. Lift the brushroll out by using the pull-tab on the left side. You can test the brushroll once it has been inserted by plugging the vacuum in and running the vacuum in carpet mode.  The brushroll indicator light should be a solid green color.
    • Lift the brushroll out by using the pull-tab on the left side.
    • You can test the brushroll once it has been inserted by plugging the vacuum in and running the vacuum in carpet mode. The brushroll indicator light should be a solid green color.
  4. Remove the five 5mm Torx #9 screws on the front side.
    • Remove the five 5mm Torx #9 screws on the front side.
  5. Remove the six 7.5mm Torx #20 screws on the bottom face of the nozzle.
    • Remove the six 7.5mm Torx #20 screws on the bottom face of the nozzle.
    • A screwdriver extension may be necessary to reach the screw closest to the center of the nozzle.
  6. Remove the top panel by lifting the top piece off of the bottom.
    • Remove the top panel by lifting the top piece off of the bottom.
    • There will be loud clicking noises.
  7. If you are trying to remove the belt, you may skip to the next step.
    • If you are trying to remove the belt, you may skip to the next step.
    • Remove the 7.5mm Torx #20 screw in front of the motor.
    • The motor is the gray block on the right side of the floor nozzle (when the nozzle faces towards you).
  8. If you are trying to remove the belt, you may skip to the next step. Remove the panel to reveal the motor screw.
    • Remove the panel to reveal the motor screw.
    • Remove the 7.5mm Torx #20 motor screw.
    • Remove the motor.
  9. Remove the black belt located on the right face of the vacuum nozzle.
    • Remove the black belt located on the right face of the vacuum nozzle.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Samantha Woo
회원 가입일: 2017년 10월 02일
303 평판
안내서 2개 작성하였습니다
Cal Poly, Team S15-G7, Livingston Fall 2017 Cal Poly, Team S15-G7, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G7
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 53
전체 시간: 5,204
