주요 콘텐츠로 건너뛰기
Shark Rotator Lift-Away Speed Brushroll Motor Replacement
필요한 것
  1. Shark Rotator Lift-Away Speed Brushroll Motor Replacement, Brushroll: 1 단계, 이미지 1/1
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Locate the release button at the top of the vacuum pod next to the handle.
    • Use the handle to lift the pod up off of the vacuum nozzle while pressing the release button.
    • Removing the pod is optional, but it may be easier to locate blockages or access the motor and belt if you do so.
  2. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 2 단계, 이미지 1/2 Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 2 단계, 이미지 2/2
    • Press the Brushroll Access buttons on the top of the nozzle to reveal the brushroll compartment.
  3. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 3 단계, 이미지 1/2 Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 3 단계, 이미지 2/2
    • Lift the brushroll out by using the pull-tab on the left side.
    • You can test the brushroll once it has been inserted by plugging the vacuum in and running the vacuum in carpet mode. The brushroll indicator light should be a solid green color.
  4. Shark Rotator Lift-Away Speed Brushroll Motor Replacement, Brushroll Motor: 4 단계, 이미지 1/1
    • Remove the five 5mm Torx #9 screws on the front side.
  5. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 5 단계, 이미지 1/1
    • Remove the six 7.5mm Torx #20 screws on the bottom face of the nozzle.
    • A screwdriver extension may be necessary to reach the screw closest to the center of the nozzle.
  6. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 6 단계, 이미지 1/1
    • Remove the top panel by lifting the top piece off of the bottom.
    • There will be loud clicking noises.
  7. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 7 단계, 이미지 1/1
    • If you are trying to remove the belt, you may skip to the next step.
    • Remove the 7.5mm Torx #20 screw in front of the motor.
    • The motor is the gray block on the right side of the floor nozzle (when the nozzle faces towards you).
  8. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 8 단계, 이미지 1/2 Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 8 단계, 이미지 2/2
    • Remove the panel to reveal the motor screw.
    • Remove the 7.5mm Torx #20 motor screw.
    • Remove the motor.
결론
Weston Mongomery
회원 가입일: 10/02/17
201 평판
안내서 2개 작성하였습니다
Cal Poly, Team S15-G7, Livingston Fall 2017 Cal Poly, Team S15-G7, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G7
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 24
전체 시간: 3,731
