주요 콘텐츠로 건너뛰기
Shark Rotator Lift-Away Speed Brushroll Replacement
필요한 것
  1. Shark Rotator Lift-Away Speed Brushroll Replacement, Brushroll: 1 단계, 이미지 1/1
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Locate the release button at the top of the vacuum pod next to the handle.
    • Use the handle to lift the pod up off of the vacuum nozzle while pressing the release button.
    • Removing the pod is optional, but it may be easier to locate blockages or access the motor and belt if you do so.
  2. Shark Rotator Lift-Away Speed Brushroll Replacement: 2 단계, 이미지 1/2 Shark Rotator Lift-Away Speed Brushroll Replacement: 2 단계, 이미지 2/2
    • Press the Brushroll Access buttons on the top of the nozzle to reveal the brushroll compartment.
  3. Shark Rotator Lift-Away Speed Brushroll Replacement: 3 단계, 이미지 1/2 Shark Rotator Lift-Away Speed Brushroll Replacement: 3 단계, 이미지 2/2
    • Lift the brushroll out by using the pull-tab on the left side.
    • You can test the brushroll once it has been inserted by plugging the vacuum in and running the vacuum in carpet mode. The brushroll indicator light should be a solid green color.
결론
Weston Mongomery
회원 가입일: 10/02/17
201 평판
안내서 2개 작성하였습니다
Cal Poly, Team S15-G7, Livingston Fall 2017 Cal Poly, Team S15-G7, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G7
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 1,798
