주요 콘텐츠로 건너뛰기
Shark Rotator Lift-Away Speed Filter Replacement
  1. Shark Rotator Lift-Away Speed Filter Replacement, Filter: 1 단계, 이미지 1/3 Shark Rotator Lift-Away Speed Filter Replacement, Filter: 1 단계, 이미지 2/3 Shark Rotator Lift-Away Speed Filter Replacement, Filter: 1 단계, 이미지 3/3
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Lay the vacuum pod flat with the bottom facing towards you.
    • Pull the silver release latch and lift away from the body of the vacuum from the bottom.
  2. Shark Rotator Lift-Away Speed Filter Replacement: 2 단계, 이미지 1/1
    • Lift the front cover off the face of the vacuum body.
    • Pull out the filter.
    • This filter should be replaced or washed once a year.
  3. Shark Rotator Lift-Away Speed Filter Replacement: 3 단계, 이미지 1/3 Shark Rotator Lift-Away Speed Filter Replacement: 3 단계, 이미지 2/3 Shark Rotator Lift-Away Speed Filter Replacement: 3 단계, 이미지 3/3
    • Rest the vacuum pod upright.
    • Press down on the buttons on either side of the handle labeled “dust cup release.”
    • Lift the dust cup away from from the body of the vacuum to uncover the foam filter.
    • In most Shark manuals, the vacuum pod is referred to as the "Lift-Away Pod."
  4. Shark Rotator Lift-Away Speed Filter Replacement: 4 단계, 이미지 1/2 Shark Rotator Lift-Away Speed Filter Replacement: 4 단계, 이미지 2/2
    • Lift the foam filter and filter frame out of the center of the vacuum to unveil the felt filter.
    • Remove the felt filter by lifting the pull-tab.
    • These filters should be replaced or washed every three months.
    • Do not use the vacuum without the dust cup and filters in place.
결론
Julia Sullivan
회원 가입일: 10/02/17
107 평판
안내서 1개 작성함
Cal Poly, Team S15-G7, Livingston Fall 2017 Cal Poly, Team S15-G7, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G7
4 회원들
안내서 10개 작성하였습니다
댓글 3개
I cleaned all filters vacuum a rug and then went to regular floors and the vacuum stopped all together I don't know what it is belt looks new
donnaweitz4849@gmail.com - 답글
I cleaned all filters let them dry then replaced to vacuum started vacuum and it ran less than 5minutes and it shut down
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 20
30일 전: 94
전체 시간: 10,700
