주요 콘텐츠로 건너뛰기
Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement
  1. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement, Hose and Wand Attachment: 1 단계, 이미지 1/1
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Place the vacuum upright and locate the attachment you want removed.
  2. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: 2 단계, 이미지 1/3 Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: 2 단계, 이미지 2/3 Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: 2 단계, 이미지 3/3
    • Slide the attachments off of the end of the wand.
    • Some attachments may have a "Release" button--if so, hold down the button while sliding the attachment off.
    • The back of the vacuum has slots to hold up to two vacuum attachments. To store, simply place the attachment onto the circular slots.
  3. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: 3 단계, 이미지 1/2 Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: 3 단계, 이미지 2/2
    • Locate the button that says “Release Wand” and press down.
    • Press button while lifting upwards on the handle at the top of the wand.
  4. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: 4 단계, 이미지 1/2 Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: 4 단계, 이미지 2/2
    • Locate the black hose on the back of the vacuum.
    • Locate the silver release levers on the top and bottom of the hose.
    • Press on the silver release levers and pull up and away from the device to release the hose.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Samantha Woo
회원 가입일: 10/02/17
330 평판
안내서 2개 작성하였습니다
Cal Poly, Team S15-G7, Livingston Fall 2017 Cal Poly, Team S15-G7, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G7
4 회원들
안내서 10개 작성하였습니다
댓글 4개
I cannot figure out how to attach het attachments for my new Shark Rotary 752. They just will not go in.
Sandra Groeninger - 답글
I have a shark duoclean Hv3900k and have attached the dusting accessory but I can't get it off after hoovering my staircase
ac002n1397 - 답글
A small white plastic ring which attaches the hose to the junction of the rotating part of machine. the model is NV50101, Shark Rotator Professional. Since I can't keep the hose connected to the vacuum, it cannot be used.
Gilda Allen - 답글
The small white plastic ring on the bottom of the hose is broken and thus the hose will not lock into place.
Gilda Allen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 26
30일 전: 118
전체 시간: 18,316
