소개
When the roller brush motor breaks, the roller brush will not spin. The motor can break due to electrical malfunctions or even broken pieces inside.
필요한 것
Pull the handle while pressing the lift away button to remove the body of the vacuum.
Lift the motor out of the base.
Disconnect the pins attaching the wires to the motor by pulling on the pins.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 6개
Did you ever find a board, Dave?
Wife took all apart; quite impressed - but what voltage does beater motor run at? Gotta get a multimeter which are cheap now; Ck red and white leads to cute little motor; and if no power is reaching motor i’ll have the same question as DAVE… and also need to find part (and price of part) if it’s fhe motor …
I’m in the same boat here, Pretty sure my brush motor is going out. It keeps stuttering. I’ve cleaned everything but the filters. If cleaned filters don’t fix the problem, which I don’t know why they would, I need to buy a new brush motor. I don’t want to trash a vacuum only because of a easy to replace motor piece. If anyone finds where to buy it let us know!
