주요 콘텐츠로 건너뛰기
Shark Rotator NV502 Roller Brush Replacement
필요한 것
  1. Shark Rotator NV502 Roller Brush Replacement, Roller Brush: 1 단계, 이미지 2개 중 1개 Shark Rotator NV502 Roller Brush Replacement, Roller Brush: 1 단계, 이미지 2개 중 2개
    • Pull the handle while pressing the lift away button to remove the body of the vacuum.
  2. Shark Rotator NV502 Roller Brush Replacement: 2 단계, 이미지 2개 중 1개 Shark Rotator NV502 Roller Brush Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the base of the vacuum over to access the bottom.
    • Remove the two small wheels with a metal spudger.
  3. Shark Rotator NV502 Roller Brush Replacement: 3 단계, 이미지 2개 중 1개 Shark Rotator NV502 Roller Brush Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the nine 16 mm screws using the Phillips #2 Screwdriver. Press on the side tabs in the middle of the panel and pull up to reveal the screw under the hose connection.
    • Remove the two 13.5 mm screws using the Phillips #2 Screwdriver.
  4. Shark Rotator NV502 Roller Brush Replacement: 4 단계, 이미지 2개 중 1개 Shark Rotator NV502 Roller Brush Replacement: 4 단계, 이미지 2개 중 2개
    • Pull up on the cover and move it to the side.
    • Remove the wire attached to the base by squeezing the pin and pulling up.
  5. Shark Rotator NV502 Roller Brush Replacement: 5 단계, 이미지 2개 중 1개 Shark Rotator NV502 Roller Brush Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the two 11 mm screws using the Phillips #2 screwdriver.
    • Lift the roller brush cover up.
  6. Shark Rotator NV502 Roller Brush Replacement: 6 단계, 이미지 1개 중 1개
    • Pull out the roller brush.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Samuel
회원 가입일: 10/06/16
338 평판
안내서 3개를 작성함
Cal Poly, Team 4-3, Livingston Fall 2016 Cal Poly, Team 4-3, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S4G3
4 회원들
안내서 19개를 작성함
7가이드 댓글
Good day, I have a rotator lift away NV500 my belt indicator light stopped working but I was still getting suction. I replaced the filters and hep filters,as well as changed the belt. I cleaned off the dust and then carefully put the vacuum back to gather. I went to plug it in all worked until I pushed the roller brush indicator on and it still did not work. What else could it be? Any suggestions.
I await your reply
Angela
Angela Cox - 답글
I have the same issue…brush roller will not work.
csweetccr - 답글
Same here what would be wrong with it
Johnnie Twyman -
Great instructions - the 11mm hidden screws plus one more were tricky to find. Thanks so much for the great graphics and very clear disassembly steps; I almost gave up and was going to take it to a dealer for a costly repair fee. Thanks again!
Mathew Curran - 답글
Great directions and guidance - many thanks!
Mathew Curran - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 22
지난 30일: 97
전체 시간: 28,654
