주요 콘텐츠로 건너뛰기
Shark Rotator Powered Lift-Away Roller Brush Replacement
필요한 것
  1. Shark Rotator Powered Lift-Away Roller Brush Replacement, Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 1 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Roller Brush Replacement, Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 1 단계, 이미지 2/2
    • Push the lift away button and pull the handle up to separate the body from the wand section.
  2. Shark Rotator Powered Lift-Away Roller Brush Replacement: 2 단계, 이미지 1/1
    • Push lift away button on the wand then lift up on the top section to separate.
  3. Shark Rotator Powered Lift-Away Roller Brush Replacement: 3 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Roller Brush Replacement: 3 단계, 이미지 2/2
    • Tilt the wand shaft backwards for convenient.
  4. Shark Rotator Powered Lift-Away Roller Brush Replacement: 4 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Roller Brush Replacement: 4 단계, 이미지 2/2
    • Lay the head nozzle piece upside down.
    • Rotate the three gray taps to the unlock position.
  5. Shark Rotator Powered Lift-Away Roller Brush Replacement: 5 단계, 이미지 1/1
    • With your fingers, pry and pull the brush cage open.
  6. Shark Rotator Powered Lift-Away Roller Brush Replacement: 6 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Roller Brush Replacement: 6 단계, 이미지 2/2
    • Remove the 13 screws (circled in yellow) using a phillips screwdriver.
    • Be sure to keep track of which screws go into which hole.
    • Remove the one screw (circled in red) that has a Torx head (might be Phillips head on some models).
    • The Torx screw is hidden under a rubber gasket. Carefully, lift up the gasket without damaging it to access this screw.
    • Remove the horizontal screw (circled in orange) that attaches the gray side panel (necessary to remove the white cap on the roller brush in step 8)
  7. Shark Rotator Powered Lift-Away Roller Brush Replacement: 7 단계, 이미지 1/1
    • Lift up the top cover now that all of the screws have been removed.
  8. Shark Rotator Powered Lift-Away Roller Brush Replacement, Roller Brush: 8 단계, 이미지 1/1
    • Remove white cap with a Flathead screwdriver or any other wedge-like tool.
  9. Shark Rotator Powered Lift-Away Roller Brush Replacement: 9 단계, 이미지 1/3 Shark Rotator Powered Lift-Away Roller Brush Replacement: 9 단계, 이미지 2/3 Shark Rotator Powered Lift-Away Roller Brush Replacement: 9 단계, 이미지 3/3
    • Gently push piece in.
    • Pull piece down and out of the container.
  10. Shark Rotator Powered Lift-Away Roller Brush Replacement: 10 단계, 이미지 1/1
    • Turn vacuum head over to remove brush.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Cameron Ngai
회원 가입일: 09/27/17
718 평판
안내서 3개 작성하였습니다
Cal Poly, Team S9-G3, Banghart Fall 2017 Cal Poly, Team S9-G3, Banghart Fall 2017 회원
CPSU-BANGHART-F17S9G3
4 회원들
안내서 12개 작성하였습니다
댓글 19개
Where do you get the rotator brush? All I can find are the two for the Navigator.
Dave - 답글
Same. Need a new brush bar.
Michael Brennan - 답글
I appreciate the info you had posted. It was easy to follow and helped me to save money on buying a new vacuum!
Ah Sum Taeza - 답글
I have the same question. Where can I find the brushbar to the Shark Rotator Professional lift-away mv650?
i’m getting a little frustrated because my carpet’s pile is not getting lifted and cleaned.
Venette
7 August 2019
crazeeincc - 답글
Does anyone get a reply?
crazeeincc - 답글
댓글 쓰기
조회 통계:
24 시간 전: 33
7일 전: 143
30일 전: 610
전체 시간: 46,832
