주요 콘텐츠로 건너뛰기
Shark Rotator Powered Lift-Away Speed Belt Replacement
필요한 것
  1. Shark Rotator Powered Lift-Away Speed Belt Replacement, Belt: 1 단계, 이미지 1/3 Shark Rotator Powered Lift-Away Speed Belt Replacement, Belt: 1 단계, 이미지 2/3 Shark Rotator Powered Lift-Away Speed Belt Replacement, Belt: 1 단계, 이미지 3/3
    • Turn the vacuum on its side.
    • Using a quarter, twist the three green locks to the unlock position.
    • Pull the bottom roller brush cover to open the vacuum.
  2. Shark Rotator Powered Lift-Away Speed Belt Replacement: 2 단계, 이미지 1/1
    • Using a T20 screwdriver, remove the five 15.9 mm screws on the outside cover.
  3. Shark Rotator Powered Lift-Away Speed Belt Replacement: 3 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Speed Belt Replacement: 3 단계, 이미지 2/2
    • Remove the three 14.3 mm screws with a T20 screwdriver.
  4. Shark Rotator Powered Lift-Away Speed Belt Replacement: 4 단계, 이미지 1/1
    • Remove the two 14.3 mm screws under the wheels with a T20 screwdriver bit.
  5. Shark Rotator Powered Lift-Away Speed Belt Replacement: 5 단계, 이미지 1/1
    • Remove the two 15.9 mm screws from behind the wheels with a T20 bit screwdriver.
  6. Shark Rotator Powered Lift-Away Speed Belt Replacement: 6 단계, 이미지 1/1
    • Remove the single 13.4 mm small screw behind the roller brush with a PH0 screwdriver bit.
  7. Shark Rotator Powered Lift-Away Speed Belt Replacement: 7 단계, 이미지 1/1
    • Remove the single 13.4 mm screw from behind the belted end of the roller brush with a T20 screwdriver bit.
  8. Shark Rotator Powered Lift-Away Speed Belt Replacement: 8 단계, 이미지 1/3 Shark Rotator Powered Lift-Away Speed Belt Replacement: 8 단계, 이미지 2/3 Shark Rotator Powered Lift-Away Speed Belt Replacement: 8 단계, 이미지 3/3
    • Turn the vacuum around.
    • Using a spudger, pry the top of the vacuum cover off. There are three tabs behind each of the clear rectangles below the headlights.
  9. Shark Rotator Powered Lift-Away Speed Belt Replacement: 9 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Speed Belt Replacement: 9 단계, 이미지 2/2
    • Remove both of the headlight covers with the spudger.
  10. Shark Rotator Powered Lift-Away Speed Belt Replacement: 10 단계, 이미지 1/3 Shark Rotator Powered Lift-Away Speed Belt Replacement: 10 단계, 이미지 2/3 Shark Rotator Powered Lift-Away Speed Belt Replacement: 10 단계, 이미지 3/3
    • Remove the grey side panel on the motor side of the vaccum with a spudger. Pry under each tab to release the side panel.
  11. Shark Rotator Powered Lift-Away Speed Belt Replacement: 11 단계, 이미지 1/1
    • Remove the two 13.4 mm screws with a T20 bit screwdriver.
  12. Shark Rotator Powered Lift-Away Speed Belt Replacement: 12 단계, 이미지 1/1
    • Remove the single 13.4 mm screw located next to where the belt was detached, securing the motor in place, with a PH1 screwdriver.
  13. Shark Rotator Powered Lift-Away Speed Belt Replacement: 13 단계, 이미지 1/3 Shark Rotator Powered Lift-Away Speed Belt Replacement: 13 단계, 이미지 2/3 Shark Rotator Powered Lift-Away Speed Belt Replacement: 13 단계, 이미지 3/3
    • Remove the visible side of the belt from the gear with a spudger.
  14. Shark Rotator Powered Lift-Away Speed Belt Replacement: 14 단계, 이미지 1/1
    • Remove the grey panel from the opposite side, by uncrewing the single 13.4 mm screw with a PH1 screwdriver. This will release the container for the roller brush and belt motor.
  15. Shark Rotator Powered Lift-Away Speed Belt Replacement: 15 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Speed Belt Replacement: 15 단계, 이미지 2/2
    • Using the spudger, push the white end cap out of the clear plastic by placing the spudger on the roller brush side and pushing the cap outward.
  16. Shark Rotator Powered Lift-Away Speed Belt Replacement: 16 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Speed Belt Replacement: 16 단계, 이미지 2/2
    • Remove the belt from the gear.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Dakota Rodriguez-Ransom
회원 가입일: 10/08/18
605 평판
안내서 2개 작성하였습니다
Cal Poly, Team S4-G6, White Fall 2018 Cal Poly, Team S4-G6, White Fall 2018 회원
CPSU-WHITE-F18S4G6
4 회원들
안내서 12개 작성하였습니다
댓글 2개
Where can we buy belts in UK?
Greg Norman - 답글
where cn i get a belt for this vaccum
Annie Pappineau - 답글
댓글 쓰기
조회 통계:
24 시간 전: 31
7일 전: 194
30일 전: 892
전체 시간: 38,406
