주요 콘텐츠로 건너뛰기
Shark Rotator Powered Lift-Away Speed Filter Replacement
  1. Shark Rotator Powered Lift-Away Speed Filter Replacement, Filter: 1 단계, 이미지 1/3 Shark Rotator Powered Lift-Away Speed Filter Replacement, Filter: 1 단계, 이미지 2/3 Shark Rotator Powered Lift-Away Speed Filter Replacement, Filter: 1 단계, 이미지 3/3
    • Press on the lift away button and pull away from the vacuum.
  2. Shark Rotator Powered Lift-Away Speed Filter Replacement: 2 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Speed Filter Replacement: 2 단계, 이미지 2/2
    • Press down on the hose release button and pull away from the vacuum.
  3. Shark Rotator Powered Lift-Away Speed Filter Replacement: 3 단계, 이미지 1/3 Shark Rotator Powered Lift-Away Speed Filter Replacement: 3 단계, 이미지 2/3 Shark Rotator Powered Lift-Away Speed Filter Replacement: 3 단계, 이미지 3/3
    • Pull the dust cup release latch and lift the dust cup from where it rests.
  4. Shark Rotator Powered Lift-Away Speed Filter Replacement: 4 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Speed Filter Replacement: 4 단계, 이미지 2/2
    • Pull out the foam filter from where the dust cup rested.
  5. Shark Rotator Powered Lift-Away Speed Filter Replacement: 5 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Speed Filter Replacement: 5 단계, 이미지 2/2
    • Pull out the felt filter from where the foam filter rested.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sujey Ruano
회원 가입일: 10/08/18
706 평판
안내서 3개 작성하였습니다
Cal Poly, Team S4-G6, White Fall 2018 Cal Poly, Team S4-G6, White Fall 2018 회원
CPSU-WHITE-F18S4G6
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 23
전체 시간: 3,209
