주요 콘텐츠로 건너뛰기
Shark Rotator Powered Lift-Away Speed Hose Replacement
필요한 것
  1. Shark Rotator Powered Lift-Away Speed Hose Replacement, Hose: 1 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Speed Hose Replacement, Hose: 1 단계, 이미지 2/2
    • Press down on the hose release button and pull away from the vacuum
  2. Shark Rotator Powered Lift-Away Speed Hose Replacement: 2 단계, 이미지 1/3 Shark Rotator Powered Lift-Away Speed Hose Replacement: 2 단계, 이미지 2/3 Shark Rotator Powered Lift-Away Speed Hose Replacement: 2 단계, 이미지 3/3
    • Press down on the wand release button and remove the wand from the vacuum.
  3. Shark Rotator Powered Lift-Away Speed Hose Replacement: 3 단계, 이미지 1/3 Shark Rotator Powered Lift-Away Speed Hose Replacement: 3 단계, 이미지 2/3 Shark Rotator Powered Lift-Away Speed Hose Replacement: 3 단계, 이미지 3/3
    • Press down on the handle release button and pull the wand away from the vacuum.
  4. Shark Rotator Powered Lift-Away Speed Hose Replacement: 4 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Speed Hose Replacement: 4 단계, 이미지 2/2
    • Remove five 13.4 mm screws from the handle with a T20 Torx bit.
  5. Shark Rotator Powered Lift-Away Speed Hose Replacement: 5 단계, 이미지 1/1
    • Using a T20 Torx bit, remove the two 13.4 mm screws from the front of the nozzle.
  6. Shark Rotator Powered Lift-Away Speed Hose Replacement: 6 단계, 이미지 1/3 Shark Rotator Powered Lift-Away Speed Hose Replacement: 6 단계, 이미지 2/3 Shark Rotator Powered Lift-Away Speed Hose Replacement: 6 단계, 이미지 3/3
    • Remove the neck ring by placing a spudger under the brace and lifting outwards.
    • It may be helpful to use a heat gun on the brace and then attempt removing with a spudger.
  7. Shark Rotator Powered Lift-Away Speed Hose Replacement: 7 단계, 이미지 1/1
    • Run the spudger along the center seam of the handle, pulling it apart as you go.
  8. Shark Rotator Powered Lift-Away Speed Hose Replacement: 8 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Speed Hose Replacement: 8 단계, 이미지 2/2
    • Remove the single 13.4 mm screw at the bottom of the handle grip and then lift the grip with a spudger.
  9. Shark Rotator Powered Lift-Away Speed Hose Replacement: 9 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Speed Hose Replacement: 9 단계, 이미지 2/2
    • Remove the single 13.4 mm screw from underneath the handle grip. You are then able to open the handle using a spudger and pulling the pieces apart.
  10. Shark Rotator Powered Lift-Away Speed Hose Replacement: 10 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Speed Hose Replacement: 10 단계, 이미지 2/2
    • Using two spudgers, unclip the hose from the handle.
  11. Shark Rotator Powered Lift-Away Speed Hose Replacement: 11 단계, 이미지 1/2 Shark Rotator Powered Lift-Away Speed Hose Replacement: 11 단계, 이미지 2/2
    • Use wire cutters to clip the white and black wire that connect the hose to the handle.
    • Soldering or wire connectors are necessary for reassembly.
    • Any time you are dealing with electrical components, be sure the device is unplugged.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Sujey Ruano
회원 가입일: 10/08/18
706 평판
안내서 3개 작성하였습니다
Cal Poly, Team S4-G6, White Fall 2018 Cal Poly, Team S4-G6, White Fall 2018 회원
CPSU-WHITE-F18S4G6
4 회원들
안내서 12개 작성하였습니다
댓글 2개
Very helpful! I got a sock super stuck. I tried all the conventional methods to get it out but ended up needing to take the hose apart. Excellent instructions that got the job done with no lasting damage.
Jason Woehl - 답글
My Shark Vertex looks suspiciously like this unit. Maybe I should return it before I have problems that require me to do all this!
My first Shark lasted almost 20 years without a hitch. It was finally taken down by a plastic part inside the unit that I have been unable to locate. It would be quite an easy repair save the plastic part securing the handled hose to the body.
Yikes!
Edward Darbonne - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 58
30일 전: 230
전체 시간: 8,753
