소개
Are you experiencing a loss of suction? If so, an easy first step would be to check the vacuum's suction hose for any clogs, rips or separations, replace the suction hose assembly as necessary.
필요한 것
On the top portion of the suction hose, firmly press the tab.
Next, pull the suction hose up to detach it.
On the bottom portion of the suction hose, press the tab and pull the hose out.
다른 2명이 해당 안내서를 완성하였습니다.
