주요 콘텐츠로 건너뛰기
Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement
  1. Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement, HEPA Filter: 1 단계, 이미지 1/2 Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement, HEPA Filter: 1 단계, 이미지 2/2
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement: 2 단계, 이미지 1/2 Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement: 2 단계, 이미지 2/2
    • Remove the red cover from the front of the vacuum by pulling the latch found at the bottom of the cover forward and moving the whole cover downward.
  3. Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement: 3 단계, 이미지 1/2 Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement: 3 단계, 이미지 2/2
    • Remove the filter by pulling it straight out.
    • To clean the filter, rinse it under water and allow it to dry before placing it back in the vacuum.
결론
Carson Craft
회원 가입일: 01/24/18
251 평판
안내서 1개 작성함
Cal Poly, Team S19-G3, White Winter 2019 Cal Poly, Team S19-G3, White Winter 2019 회원
CPSU-WHITE-W19S19G3
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 10
전체 시간: 364
