주요 콘텐츠로 건너뛰기
Shark Rotator Slim-Light Lift-Away Upright Motor Replacement
필요한 것
  1. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: 1 단계, 이미지 2개 중 1개 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: 1 단계, 이미지 2개 중 2개
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 2 단계, 이미지 3개 중 1개 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 2 단계, 이미지 3개 중 2개 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the two 19mm Phillips #2 screws located in the red plastic piece behind the filter.
  3. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 3 단계, 이미지 3개 중 1개 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 3 단계, 이미지 3개 중 2개 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 3 단계, 이미지 3개 중 3개
    • Flip over vacuum and remove the six 12.7mm Phillips #2 screws from the base.
    • Take off white plastic cover exposing the motor in its insulation.
  4. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 4 단계, 이미지 3개 중 1개 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 4 단계, 이미지 3개 중 2개 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the motor from the base and slide the insulation down along the wires.
    • Find the plastic caps on top of the black and white wires. Using pliers twist and carefully remove these caps.
    • Needle nosed pliers are recommended but not necessary.
    • These plastic caps are somewhat sensitive and can be difficult to take off. Additionally once taken off they can become unusable.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Joshua Morrison
회원 가입일: 01/24/19
211 평판
안내서 2개를 작성함
Cal Poly, Team S19-G3, White Winter 2019 Cal Poly, Team S19-G3, White Winter 2019 회원
CPSU-WHITE-W19S19G3
5 회원들
안내서 12개를 작성함
2가이드 댓글
What is the motor PN and where can I get one?
Dennis Meece - 답글
Somewhere in the process I ended up with a 5" coil spring with a plastic stopper on one end about 1/2" in diameter. Can you tell me where it belongs?
Edward Van Grol - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 16
전체 시간: 1,794
