주요 콘텐츠로 건너뛰기
Shark Rotator Slim-Light Lift-Away Upright Motor Replacement
필요한 것
  1. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: 1 단계, 이미지 1/2 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: 1 단계, 이미지 2/2
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 2 단계, 이미지 1/3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 2 단계, 이미지 2/3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 2 단계, 이미지 3/3
    • Remove the two 19mm Phillips #2 screws located in the red plastic piece behind the filter.
  3. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 3 단계, 이미지 1/3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 3 단계, 이미지 2/3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 3 단계, 이미지 3/3
    • Flip over vacuum and remove the six 12.7mm Phillips #2 screws from the base.
    • Take off white plastic cover exposing the motor in its insulation.
  4. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 4 단계, 이미지 1/3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 4 단계, 이미지 2/3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: 4 단계, 이미지 3/3
    • Remove the motor from the base and slide the insulation down along the wires.
    • Find the plastic caps on top of the black and white wires. Using pliers twist and carefully remove these caps.
    • Needle nosed pliers are recommended but not necessary.
    • These plastic caps are somewhat sensitive and can be difficult to take off. Additionally once taken off they can become unusable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joshua Morrison
회원 가입일: 01/24/19
196 평판
안내서 2개 작성하였습니다
Cal Poly, Team S19-G3, White Winter 2019 Cal Poly, Team S19-G3, White Winter 2019 회원
CPSU-WHITE-W19S19G3
5 회원들
안내서 12개 작성하였습니다
댓글 한 개
What is the motor PN and where can I get one?
Dennis Meece - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 21
전체 시간: 1,497
