소개
When the roller brush is not spinning because of a broken belt or damaged teeth, you might want to consider replacing the belt.
필요한 것
Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
Remove the roller brush by sliding it out toward the left, off the belt.
거의 끝나갑니다!
결론
