주요 콘텐츠로 건너뛰기
Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement
필요한 것
  1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement, Roller Brush: 1 단계, 이미지 1/2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement, Roller Brush: 1 단계, 이미지 2/2
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 2 단계, 이미지 1/1
    • Turn over the vacuum to reveal the roller brush.
  3. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 3 단계, 이미지 1/2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 3 단계, 이미지 2/2
    • Pry the small wheels at the bottom of the base using the plastic opening tool.
  4. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 4 단계, 이미지 1/2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 4 단계, 이미지 2/2
    • Using a coin, turn the big white knobs located above the roller brush counter-clockwise.
  5. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 5 단계, 이미지 1/3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 5 단계, 이미지 2/3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 5 단계, 이미지 3/3
    • Lift up the suction hose to reveal a screw.
    • Remove the 12.7 mm Phillips #02 screw.
  6. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 6 단계, 이미지 1/2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 6 단계, 이미지 2/2
    • Remove eight 12.7mm screws located under the vacuum using a Phillips #02 screwdriver.
    • Remove two 12.7 mm screws located next to the wheels with a Phillips #02 screwdriver.
    • The two screws located next to the wheels are smaller in diameter.
  7. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 7 단계, 이미지 1/3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 7 단계, 이미지 2/3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 7 단계, 이미지 3/3
    • Turn the vacuum upright and pull the white upper section of the brush roller circuit housing.
    • Be careful when lifting the housing as there is a connector attached.
  8. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 8 단계, 이미지 1/2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 8 단계, 이미지 2/2
    • Remove the connector attached to the circuit boards using a plastic opening tool.
  9. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 9 단계, 이미지 1/3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 9 단계, 이미지 2/3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 9 단계, 이미지 3/3
    • Remove the two 12.7 mm screws located at the top of the clear plastic brush roller housing using a Phillips #02 screwdriver.
    • Lift the clear plastic brush roller housing.
  10. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 10 단계, 이미지 1/2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 10 단계, 이미지 2/2
    • Wiggle the brush roller upwards from the left and right side slots.
결론
Daniel Ceja
회원 가입일: 01/24/19
277 평판
안내서 2개 작성하였습니다
Cal Poly, Team S19-G3, White Winter 2019 Cal Poly, Team S19-G3, White Winter 2019 회원
CPSU-WHITE-W19S19G3
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 19
전체 시간: 991
