주요 콘텐츠로 건너뛰기
Shark Steam Pocket Mop Ejection Button Assembly Replacement
필요한 것
  1. Shark Steam Pocket Mop Ejection Button Assembly Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Begin by removing the 8 quarter inch phillips head screws found along the back panel
    • Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
  2. Shark Steam Pocket Mop Ejection Button Assembly Replacement, Ejection Button Assembly: 2 단계, 이미지 3개 중 1개 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Ejection Button Assembly: 2 단계, 이미지 3개 중 2개 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Ejection Button Assembly: 2 단계, 이미지 3개 중 3개
    • Begin by removing the two quarter inch Phillips head screws you see pictured. These screws hold the bottom part of the button assembly to the Mop's midframe.
    • Be very careful not to lose the spring that is in between the top and bottom part of the button assembly.
  3. Shark Steam Pocket Mop Ejection Button Assembly Replacement: 3 단계, 이미지 2개 중 1개 Shark Steam Pocket Mop Ejection Button Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Once the bottom piece of the assembly has been removed, carefully turn the mop over and move the front panel of the mop to the side
    • Once you've turned your device over you should be able to remove the top portion of the button assembly with ease. It should not require anything more than your fingers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jacob Howe
회원 가입일: 10/10/17
549 평판
안내서 5개를 작성함
USF Tampa, Team S13-G7, Cagle Fall 2017 USF Tampa, Team S13-G7, Cagle Fall 2017 회원
USFT-CAGLE-F17S13G7
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 412
