주요 콘텐츠로 건너뛰기
Shark Steam Pocket Mop Power Cable Replacement
필요한 것
  1. Shark Steam Pocket Mop Power Cable Replacement, Back Panel: 1 단계, 이미지 1/3 Shark Steam Pocket Mop Power Cable Replacement, Back Panel: 1 단계, 이미지 2/3 Shark Steam Pocket Mop Power Cable Replacement, Back Panel: 1 단계, 이미지 3/3
    • Begin by removing the 8 quarter inch phillips head screws found along the back panel
    • Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
  2. Shark Steam Pocket Mop Power Cable Replacement, Power Cable: 2 단계, 이미지 1/2 Shark Steam Pocket Mop Power Cable Replacement, Power Cable: 2 단계, 이미지 2/2
    • Start by removing the two 1/8th inch Phillips head screws with your Phillips head screwdriver.
    • Gently remove the small plastic piece holding the wires against the plastic midframe of the mop.
    • Next use your wire cutters to remove the two plastic connectors and replace those wires with your new ones.
결론
Jacob Howe
회원 가입일: 10/10/17
549 평판
안내서 5개 작성하였습니다
USF Tampa, Team S13-G7, Cagle Fall 2017 USF Tampa, Team S13-G7, Cagle Fall 2017 회원
USFT-CAGLE-F17S13G7
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 35
전체 시간: 1,729
