주요 콘텐츠로 건너뛰기
Shark Steam Pocket Mop Steam Head Hose Replacement
필요한 것
  1. Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: 1 단계, 이미지 3개 중 1개 Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: 1 단계, 이미지 3개 중 2개 Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: 1 단계, 이미지 3개 중 3개
    • Start by removing this quarter inch Phillips head screw
    • Next remove the two 1/8th inch Phillips head screws at the bottom of the connector piece.
    • Next remove the nine 1/8th inch Phillips head screws along the base of the steam head connection.
    • Next remove the two 1/8th inch Phillips head screws along the base of the steam head connector.
  2. Shark Steam Pocket Mop Steam Head Hose Replacement: 2 단계, 이미지 3개 중 1개 Shark Steam Pocket Mop Steam Head Hose Replacement: 2 단계, 이미지 3개 중 2개 Shark Steam Pocket Mop Steam Head Hose Replacement: 2 단계, 이미지 3개 중 3개
    • Once all the screws are removed and the baseplate of the steam head connection has been placed aside, gently remove the connector from the bottom of the base.
    • Gently remove the end caps of the hinge piece of the connector piece with your fingers.
    • Gently remove the host connection from the back plate.
  3. Shark Steam Pocket Mop Steam Head Hose Replacement: 3 단계, 이미지 2개 중 1개 Shark Steam Pocket Mop Steam Head Hose Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use your tweezers to remove the metal ring holding the hose to the plastic end piece and replace the hose / bit as needed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jacob Howe
회원 가입일: 10/10/17
549 평판
안내서 5개를 작성함
USF Tampa, Team S13-G7, Cagle Fall 2017 USF Tampa, Team S13-G7, Cagle Fall 2017 회원
USFT-CAGLE-F17S13G7
4 회원들
안내서 10개를 작성함
3가이드 댓글
Ok, but where do I get a replacement hose?
semajrolyat - 답글
Same question as semajrolyat: where to source replacement hose?
CLIFTON CHANG - 답글
Where do you get the hose
ErnestKurschatjr@aol.com - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 5
지난 30일: 31
전체 시간: 2,407
