주요 콘텐츠로 건너뛰기
Shark Steam Pocket Mop Water Tank / Bladder Replacement
필요한 것
  1. Shark Steam Pocket Mop Water Tank / Bladder Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Shark Steam Pocket Mop Water Tank / Bladder Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Shark Steam Pocket Mop Water Tank / Bladder Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Begin by removing the 8 quarter inch phillips head screws found along the back panel
    • Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
  2. Shark Steam Pocket Mop Water Tank / Bladder Replacement, Water Tank / Bladder: 2 단계, 이미지 2개 중 1개 Shark Steam Pocket Mop Water Tank / Bladder Replacement, Water Tank / Bladder: 2 단계, 이미지 2개 중 2개
    • Start by gently moving the midframe from the top portion of the panel to expose the bottom portion of the mop's water tank / bladder.
  3. Shark Steam Pocket Mop Water Tank / Bladder Replacement: 3 단계, 이미지 3개 중 1개 Shark Steam Pocket Mop Water Tank / Bladder Replacement: 3 단계, 이미지 3개 중 2개 Shark Steam Pocket Mop Water Tank / Bladder Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the 10 quarter inch phillips head screws from the bottom portion of the water tank / bladder.
    • Then gently lift the water tank / bladder out of its plastic housing. and turn it over.
    • To fully remove the water tank / bladder, use your tweezers to remove the metal ring that keeps the hose fastened to the plastic tank.
결론
작성자
2다른 기여자 명과 함께
Jacob Howe
회원 가입일: 10/10/17
549 평판
안내서 5개를 작성함
USF Tampa, Team S13-G7, Cagle Fall 2017 USF Tampa, Team S13-G7, Cagle Fall 2017 회원
USFT-CAGLE-F17S13G7
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 892
