주요 콘텐츠로 건너뛰기
Shark Ultimate Professional Circuit Board Replacement
필요한 것
  1. Shark Ultimate Professional Circuit Board Replacement, Circuit Board: 1 단계, 이미지 3개 중 1개 Shark Ultimate Professional Circuit Board Replacement, Circuit Board: 1 단계, 이미지 3개 중 2개 Shark Ultimate Professional Circuit Board Replacement, Circuit Board: 1 단계, 이미지 3개 중 3개
    • Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure the iron is unplugged and cooled off.
  2. Shark Ultimate Professional Circuit Board Replacement: 2 단계, 이미지 2개 중 1개 Shark Ultimate Professional Circuit Board Replacement: 2 단계, 이미지 2개 중 2개
    • Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
    • Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Circuit Board Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the split end of the power cord upward through the ball joint.
    • Set aside the power cord.
  4. Shark Ultimate Professional Circuit Board Replacement: 4 단계, 이미지 3개 중 1개 Shark Ultimate Professional Circuit Board Replacement: 4 단계, 이미지 3개 중 2개 Shark Ultimate Professional Circuit Board Replacement: 4 단계, 이미지 3개 중 3개
    • Use the Philips head #0 screwdriver to remove the remaining 6.58mm screws that hold the wires on the bottom (brown and blue).
    • Remove from left to right
    • Unclip the black adapter piece on the bottom right.
    • Wires order (from left to right): Brown, Blue, Red, Black
  5. Shark Ultimate Professional Circuit Board Replacement: 5 단계, 이미지 2개 중 1개 Shark Ultimate Professional Circuit Board Replacement: 5 단계, 이미지 2개 중 2개
    • Use the Philips head #0 screwdriver to remove the two 9.75mm screws (left and right) affixed to the circuit board.
  6. Shark Ultimate Professional Circuit Board Replacement: 6 단계, 이미지 2개 중 1개 Shark Ultimate Professional Circuit Board Replacement: 6 단계, 이미지 2개 중 2개
    • Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
    • Gently pull the circuit board from affixed position.
    • The circuit board will not be completely separated at this point.
  7. Shark Ultimate Professional Circuit Board Replacement: 7 단계, 이미지 3개 중 1개 Shark Ultimate Professional Circuit Board Replacement: 7 단계, 이미지 3개 중 2개 Shark Ultimate Professional Circuit Board Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the mode display piece and set aside.
    • Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
  8. Shark Ultimate Professional Circuit Board Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the connecting wire from the connected adapter in the handle by pulling lightly.
    • Set aside the circuit board.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Drew Carff
회원 가입일: 10/23/17
868 평판
안내서 5개를 작성함
4가이드 댓글
My shark 1505C does not have philips screws on the back. They are security torx and I cannot find a tool to open it.
Where can I buy a main board for this iron ?
Thanks
NevG.
nevstarg - 답글
where do I buy it's circuit board?
egovieira - 답글
Where can u buy the circuit board professional 1800 version?
Astinder Singhera - 답글
How much does the circuit board cost? and where can i purchase it?
D.A. Willis - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 63
전체 시간: 3,867
