주요 콘텐츠로 건너뛰기
Shark Ultimate Professional Mode Display Replacement
필요한 것
  1. Shark Ultimate Professional Mode Display Replacement, Mode Display: 1 단계, 이미지 1/3 Shark Ultimate Professional Mode Display Replacement, Mode Display: 1 단계, 이미지 2/3 Shark Ultimate Professional Mode Display Replacement, Mode Display: 1 단계, 이미지 3/3
    • Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure the iron is unplugged and cooled off.
  2. Shark Ultimate Professional Mode Display Replacement: 2 단계, 이미지 1/2 Shark Ultimate Professional Mode Display Replacement: 2 단계, 이미지 2/2
    • Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
    • Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Mode Display Replacement: 3 단계, 이미지 1/3 Shark Ultimate Professional Mode Display Replacement: 3 단계, 이미지 2/3 Shark Ultimate Professional Mode Display Replacement: 3 단계, 이미지 3/3
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside the power cord.
  4. Shark Ultimate Professional Mode Display Replacement: 4 단계, 이미지 1/3 Shark Ultimate Professional Mode Display Replacement: 4 단계, 이미지 2/3 Shark Ultimate Professional Mode Display Replacement: 4 단계, 이미지 3/3
    • Use the Philips head #0 screwdriver to remove remaining 6.58mm screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Wires order (from left to right): Brown, Blue, Black, Red
    • Unclip the black adapter piece on the bottom right.
  5. Shark Ultimate Professional Mode Display Replacement: 5 단계, 이미지 1/2 Shark Ultimate Professional Mode Display Replacement: 5 단계, 이미지 2/2
    • Use the Philips head #0 screwdriver to remove two 9.75mm screws (left and right) affixed to circuit board.
  6. Shark Ultimate Professional Mode Display Replacement: 6 단계, 이미지 1/2 Shark Ultimate Professional Mode Display Replacement: 6 단계, 이미지 2/2
    • Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
    • Pull the circuit board out from its affixed position.
  7. Shark Ultimate Professional Mode Display Replacement: 7 단계, 이미지 1/3 Shark Ultimate Professional Mode Display Replacement: 7 단계, 이미지 2/3 Shark Ultimate Professional Mode Display Replacement: 7 단계, 이미지 3/3
    • Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
    • Remove and set aside the mode display.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Drew Carff
회원 가입일: 10/23/17
868 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G4, Leahy Fall 2017 USF Tampa, Team S1-G4, Leahy Fall 2017 회원
USFT-LEAHY-F17S1G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 643
