주요 콘텐츠로 건너뛰기
Shark Ultimate Professional Reservoir Replacement
필요한 것
  1. Shark Ultimate Professional Reservoir  Replacement, Reservoir: 1 단계, 이미지 1/3 Shark Ultimate Professional Reservoir  Replacement, Reservoir: 1 단계, 이미지 2/3 Shark Ultimate Professional Reservoir  Replacement, Reservoir: 1 단계, 이미지 3/3
    • Remove the two screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure iron is unplugged and cooled off.
  2. Shark Ultimate Professional Reservoir  Replacement: 2 단계, 이미지 1/2 Shark Ultimate Professional Reservoir  Replacement: 2 단계, 이미지 2/2
    • Remove the two screws holding the white clamp to the iron.
    • Remove the two screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Reservoir  Replacement: 3 단계, 이미지 1/1
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside power cord.
  4. Shark Ultimate Professional Reservoir  Replacement: 4 단계, 이미지 1/3 Shark Ultimate Professional Reservoir  Replacement: 4 단계, 이미지 2/3 Shark Ultimate Professional Reservoir  Replacement: 4 단계, 이미지 3/3
    • Remove remaining screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Unclip the black adapter piece on the bottom right.
    • Wires order (from left to right): Brown, Blue, Red, Black
  5. Shark Ultimate Professional Reservoir  Replacement: 5 단계, 이미지 1/2 Shark Ultimate Professional Reservoir  Replacement: 5 단계, 이미지 2/2
    • Remove two screws (left and right) affixed to circuit board.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Drew Carff
회원 가입일: 10/23/17
868 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G4, Leahy Fall 2017 USF Tampa, Team S1-G4, Leahy Fall 2017 회원
USFT-LEAHY-F17S1G4
3 회원들
안내서 10개 작성하였습니다
댓글 3개
i am trying to replace the thermal cutoff but can’s remember the wire inside how to replace
primrose33166 - 답글
I have a constant leak in the vertical position - long after the iron is cold. The repair presented is well done. However it stopped short and doesn't get to the reservoir - thanks
Dalmacca-Hame - 답글
Then WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAT?
Muhammad Ahmad - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 2,136
