주요 콘텐츠로 건너뛰기
Shark UltraCyclone CH951 U4 Motor Replacement
필요한 것
  1. Shark UltraCyclone CH951 U4 Motor Replacement, Dust Cup: 1 단계, 이미지 3개 중 1개 Shark UltraCyclone CH951 U4 Motor Replacement, Dust Cup: 1 단계, 이미지 3개 중 2개 Shark UltraCyclone CH951 U4 Motor Replacement, Dust Cup: 1 단계, 이미지 3개 중 3개
    • Press the dust cup release button and gently pull the dust cup away from the body of the vacuum.
  2. Shark UltraCyclone CH951 U4 Motor Replacement, Casing: 2 단계, 이미지 2개 중 1개 Shark UltraCyclone CH951 U4 Motor Replacement, Casing: 2 단계, 이미지 2개 중 2개
    • Use a TR9 Torx screwdriver to remove the two 8.7 mm screws previously behind the dust cup.
  3. Shark UltraCyclone CH951 U4 Motor Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two 12.2 mm screws underneath the dust cup button using a TR9 Torx screwdriver.
  4. Shark UltraCyclone CH951 U4 Motor Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the 13.9 mm screw beneath the charging port using a TR9 Torx screwdriver.
  5. Shark UltraCyclone CH951 U4 Motor Replacement: 5 단계, 이미지 1개 중 1개
    • Use the TR9 Torx screwdriver to remove two 11.6 mm screws that hold the exterior motor in place.
    • They are located underneath where the dust cup previously was and above the exterior motor.
  6. Shark UltraCyclone CH951 U4 Motor Replacement: 6 단계, 이미지 3개 중 1개 Shark UltraCyclone CH951 U4 Motor Replacement: 6 단계, 이미지 3개 중 2개 Shark UltraCyclone CH951 U4 Motor Replacement: 6 단계, 이미지 3개 중 3개
    • Run an iFixit Opening Tool under the casing along the vacuum body until the shell is removed starting around the attachment port, and sliding down towards the charging port.
    • If necessary, apply gentle force.
  7. Shark UltraCyclone CH951 U4 Motor Replacement, Motor: 7 단계, 이미지 3개 중 1개 Shark UltraCyclone CH951 U4 Motor Replacement, Motor: 7 단계, 이미지 3개 중 2개 Shark UltraCyclone CH951 U4 Motor Replacement, Motor: 7 단계, 이미지 3개 중 3개
    • Press down on the connection point of the white wire and disconnect it.
    • The connector looks like a white latch. Push down on the edge to pop it out of place.
  8. Shark UltraCyclone CH951 U4 Motor Replacement: 8 단계, 이미지 3개 중 1개 Shark UltraCyclone CH951 U4 Motor Replacement: 8 단계, 이미지 3개 중 2개 Shark UltraCyclone CH951 U4 Motor Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect the red wire by squeezing each side and gently pulling the two sides apart.
  9. Shark UltraCyclone CH951 U4 Motor Replacement: 9 단계, 이미지 3개 중 1개 Shark UltraCyclone CH951 U4 Motor Replacement: 9 단계, 이미지 3개 중 2개 Shark UltraCyclone CH951 U4 Motor Replacement: 9 단계, 이미지 3개 중 3개
    • Gently pull on the exterior motor.
    • The wires that were previously disconnected will be attached and will need to pass through the handle of the vacuum. Complete this step carefully so that no damage is done.
    • Remove the exterior motor, attached to the interior motor and battery.
  10. Shark UltraCyclone CH951 U4 Motor Replacement: 10 단계, 이미지 3개 중 1개 Shark UltraCyclone CH951 U4 Motor Replacement: 10 단계, 이미지 3개 중 2개 Shark UltraCyclone CH951 U4 Motor Replacement: 10 단계, 이미지 3개 중 3개
    • Squeeze the translucent rubber cover on the two wires and gently pull apart to disconnect both of them.
  11. Shark UltraCyclone CH951 U4 Motor Replacement: 11 단계, 이미지 1개 중 1개
    • When buying a replacement, most will come attached to a battery and new motorboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jessica Beck
회원 가입일: 01/24/25
587 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 19
전체 시간: 144
