주요 콘텐츠로 건너뛰기
Shark Vacuum Pet Hair Power Brush Roller Replacement
필요한 것
  1. Shark Vacuum Pet Hair Power Brush Roller Replacement, About the unit: 1 단계, 이미지 2개 중 1개 Shark Vacuum Pet Hair Power Brush Roller Replacement, About the unit: 1 단계, 이미지 2개 중 2개
    • This Shark model brush head consists of 7 parts: a base frame, a gear, a roller brush, two side screws, a plastic round band, and a top frame of the head.
    • Push the grey button on the back panel to open up the brush head.
  2. Shark Vacuum Pet Hair Power Brush Roller Replacement, Disassembly: 2 단계, 이미지 3개 중 1개 Shark Vacuum Pet Hair Power Brush Roller Replacement, Disassembly: 2 단계, 이미지 3개 중 2개 Shark Vacuum Pet Hair Power Brush Roller Replacement, Disassembly: 2 단계, 이미지 3개 중 3개
    • Take the purple gear, belt, and brush out of the body.
    • Save the belt as this is needed to make the unit operate.
  3. Shark Vacuum Pet Hair Power Brush Roller Replacement, Replacing the brush: 3 단계, 이미지 3개 중 1개 Shark Vacuum Pet Hair Power Brush Roller Replacement, Replacing the brush: 3 단계, 이미지 3개 중 2개 Shark Vacuum Pet Hair Power Brush Roller Replacement, Replacing the brush: 3 단계, 이미지 3개 중 3개
    • Pull out the side screws from the right and left side of the old roller brush and put them on the replacement roller brush.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Roshni Sachar
회원 가입일: 03/19/16
298 평판
안내서 1개를 작성함
15가이드 댓글
Cat hair will jam up in the small gap between the gear and the bushing on the turbine and will cause enough friction to stop the turbine. I used a needle to dig out the hair and it solved the problem.
hvabrams - 답글
Great tip! It works now! TY!
Wendy Dean -
perfect solution, could find the problem
Pat Gustafson -
Thank you so much for posting this helpful advice… it was the perfect solution to fix exactly what was happening to stop the turbine on the brush accessory for my Shark vacuum. Because I couldn’t find info anywhere else, especially - and frustratingly - the manufacturer’s site, I almost ended up purchasing a replacement part. I so appreciate your suggestion here!
Elizabeth C Lewis -
very clear and concise. took me 5 minutes with your instructions - couldn’t find anything like this on the shark site.
tigersfoot - 답글
댓글 쓰기
조회 통계:
지난 24시간: 16
지난 7일: 62
지난 30일: 321
전체 시간: 50,619
