소개
This guide will show you how to replace the brush roller motor belt on the power nozzle of the Shark IZ682H.
필요한 것
Detach the power nozzle from the vacuum and turn it so the right side is facing you. Pull down the blue tab to the direction where the arrow is facing.
The brush roller should now pop out.
Turn the three plastic locks to the unlocked position and remove the crevice tool.
Use T9 and T15 screwdrivers to remove the seven screws.
다른 한 분이 해당 안내서를 완성하였습니다.
