주요 콘텐츠로 건너뛰기
Sharp Aquos Crystal Digitizer Replacement
필요한 것
  1. Sharp Aquos Crystal Digitizer Replacement, Back Panel: 1 단계, 이미지 1/3 Sharp Aquos Crystal Digitizer Replacement, Back Panel: 1 단계, 이미지 2/3 Sharp Aquos Crystal Digitizer Replacement, Back Panel: 1 단계, 이미지 3/3
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
  2. Sharp Aquos Crystal Digitizer Replacement, USB Port: 2 단계, 이미지 1/2 Sharp Aquos Crystal Digitizer Replacement, USB Port: 2 단계, 이미지 2/2
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
  3. Sharp Aquos Crystal Digitizer Replacement: 3 단계, 이미지 1/2 Sharp Aquos Crystal Digitizer Replacement: 3 단계, 이미지 2/2
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
  4. Sharp Aquos Crystal Digitizer Replacement: 4 단계, 이미지 1/2 Sharp Aquos Crystal Digitizer Replacement: 4 단계, 이미지 2/2
    • Disconnect the wire by lifting it up with a plastic opening tool.
  5. Sharp Aquos Crystal Digitizer Replacement: 5 단계, 이미지 1/3 Sharp Aquos Crystal Digitizer Replacement: 5 단계, 이미지 2/3 Sharp Aquos Crystal Digitizer Replacement: 5 단계, 이미지 3/3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  6. Sharp Aquos Crystal Digitizer Replacement: 6 단계, 이미지 1/1
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
  7. Sharp Aquos Crystal Digitizer Replacement, Motherboard: 7 단계, 이미지 1/1
    • Peel off the black pieces of tape.
  8. Sharp Aquos Crystal Digitizer Replacement: 8 단계, 이미지 1/1
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
  9. Sharp Aquos Crystal Digitizer Replacement: 9 단계, 이미지 1/2 Sharp Aquos Crystal Digitizer Replacement: 9 단계, 이미지 2/2
    • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
  10. Sharp Aquos Crystal Digitizer Replacement: 10 단계, 이미지 1/1
    • Peel the tape off with your hands.
  11. Sharp Aquos Crystal Digitizer Replacement: 11 단계, 이미지 1/1
    • Lift the motherboard out with your hands.
  12. Sharp Aquos Crystal Digitizer Replacement, Battery: 12 단계, 이미지 1/1
    • Peel off the tape holding the battery down.
  13. Sharp Aquos Crystal Digitizer Replacement: 13 단계, 이미지 1/2 Sharp Aquos Crystal Digitizer Replacement: 13 단계, 이미지 2/2
    • Lift the battery out with your hands.
  14. Sharp Aquos Crystal Digitizer Replacement, Screen: 14 단계, 이미지 1/1
    • Replace this component with the new one.
결론
Felicia Imbriano
회원 가입일: 03/08/16
1,169 평판
안내서 8개 작성하였습니다
UMass Dartmouth, Team 7-4, Catania Spring 2016 UMass Dartmouth, Team 7-4, Catania Spring 2016 회원
UMASSD-CATANIA-S16S7G4
3 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 11
전체 시간: 1,594
