소개
If you cracked your screen or you are having issues with the touch screen, you may need to replace the screen.
부품
No parts specified.
  1. Peel back the back cover of the phone from the access point to remove it.  It should come off easily using your hands. Peel back the back cover of the phone from the access point to remove it.  It should come off easily using your hands. Peel back the back cover of the phone from the access point to remove it.  It should come off easily using your hands.
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
  2. Remove seven 3mm Star #5 screws shown in the picture with a screwdriver. Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
  3. Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off. Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
  4. Disconnect the wire by lifting it up with a plastic opening tool. Disconnect the wire by lifting it up with a plastic opening tool.
    • Disconnect the wire by lifting it up with a plastic opening tool.
  5. To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out. To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out. To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  6. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  7. After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
  8. Peel off the black pieces of tape.
    • Peel off the black pieces of tape.
  9. Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
  10. Remove the wire  from the two marked connections using tweezers to pull the wire apart from the device. Remove the wire  from the two marked connections using tweezers to pull the wire apart from the device.
    • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
  11. Peel the tape off with your hands.
    • Peel the tape off with your hands.
  12. Lift the motherboard out with your hands.
    • Lift the motherboard out with your hands.
  13. Peel off the tape holding the battery down.
    • Peel off the tape holding the battery down.
  14. Lift the battery out with your hands. Lift the battery out with your hands.
    • Lift the battery out with your hands.
  15. Replace this component with the new one.
    • Replace this component with the new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Felicia Imbriano
회원 가입일: 2016년 03월 08일
1,112 평판
안내서 8개 작성하였습니다
UMass Dartmouth, Team 7-4, Catania Spring 2016 UMass Dartmouth, Team 7-4, Catania Spring 2016 회원
UMASSD-CATANIA-S16S7G4
3 회원들
안내서 8개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 53
전체 시간: 5,080
