소개
You may need to replace your USB port if you are unable to charge your phone or if your phone charges slowly.
This guide will take tell you what tools you need and how to open your device and get to the USB component.
필요한 것
Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
