메인 콘텐츠로 스킵하기
부품
지정된 부품이 없습니다.
  1. Place the TV face down on a flat smooth surface as to not scratch the screen. Remove the four 8mm screws attaching the stand to the TV.
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Remove the four 8mm screws attaching the stand to the TV.
  2. Lift the stand off the television. Lift the stand off the television.
    • Lift the stand off the television.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. Remove the two back panels to display the audio and video inputs.. Remove the two back panels to display the audio and video inputs.. Remove the two back panels to display the audio and video inputs..
    • Remove the two back panels to display the audio and video inputs..
  5. Remove the eight 6mm Phillips screws around the edge. Remove the two 6mm Phillips near the inputs.
    • Remove the eight 6mm Phillips screws around the edge.
    • Remove the two 6mm Phillips near the inputs.
  6. Lift and remove the back case of the television.
    • Lift and remove the back case of the television.
결론
Robert Hobson
회원 가입일: 2011년 01월 20일
1,275 평판
안내서 9개 작성하였습니다
Cal Poly, Team 1-11, Amido Winter 2011 Cal Poly, Team 1-11, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G11
4 회원들
안내서 9개 작성하였습니다
How do you remove the casing of a sharp LC26SB25E ? Please.
alan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 3,061
