주요 콘텐츠로 건너뛰기
Sharp Aquos LC13B2UA Front Case Replacement
필요한 것
  1. Sharp Aquos LC13B2UA Front Case Replacement, Stand: 1 단계, 이미지 1/2 Sharp Aquos LC13B2UA Front Case Replacement, Stand: 1 단계, 이미지 2/2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA Front Case Replacement: 2 단계, 이미지 1/2 Sharp Aquos LC13B2UA Front Case Replacement: 2 단계, 이미지 2/2
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA Front Case Replacement, Back Case: 3 단계, 이미지 1/3 Sharp Aquos LC13B2UA Front Case Replacement, Back Case: 3 단계, 이미지 2/3 Sharp Aquos LC13B2UA Front Case Replacement, Back Case: 3 단계, 이미지 3/3
    • Remove the two back panels by prying them out with your hands.
  4. Sharp Aquos LC13B2UA Front Case Replacement: 4 단계, 이미지 1/2 Sharp Aquos LC13B2UA Front Case Replacement: 4 단계, 이미지 2/2
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Sharp Aquos LC13B2UA Front Case Replacement: 5 단계, 이미지 1/1
    • Using your hands, gently lift and remove the back case of the television.
  6. Sharp Aquos LC13B2UA Front Case Replacement, Motherboard: 6 단계, 이미지 1/3 Sharp Aquos LC13B2UA Front Case Replacement, Motherboard: 6 단계, 이미지 2/3 Sharp Aquos LC13B2UA Front Case Replacement, Motherboard: 6 단계, 이미지 3/3
    • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  7. Sharp Aquos LC13B2UA Front Case Replacement: 7 단계, 이미지 1/2 Sharp Aquos LC13B2UA Front Case Replacement: 7 단계, 이미지 2/2
    • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
    • Remove the green/gray to orange/gray connector from the center of the circuit board.
  8. Sharp Aquos LC13B2UA Front Case Replacement: 8 단계, 이미지 1/2 Sharp Aquos LC13B2UA Front Case Replacement: 8 단계, 이미지 2/2
    • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  9. Sharp Aquos LC13B2UA Front Case Replacement: 9 단계, 이미지 1/1
    • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
  10. Sharp Aquos LC13B2UA Front Case Replacement, Power Button: 10 단계, 이미지 1/3 Sharp Aquos LC13B2UA Front Case Replacement, Power Button: 10 단계, 이미지 2/3 Sharp Aquos LC13B2UA Front Case Replacement, Power Button: 10 단계, 이미지 3/3
    • Remove the two 6mm Phillips screws.
    • Pull the board toward you, giving you access to the power button.
  11. Sharp Aquos LC13B2UA Front Case Replacement, Top Buttons: 11 단계, 이미지 1/2 Sharp Aquos LC13B2UA Front Case Replacement, Top Buttons: 11 단계, 이미지 2/2
    • Unscrew the two 4mm Phillips screws.
    • Lift the buttons off the front case.
  12. Sharp Aquos LC13B2UA Front Case Replacement, Front Case: 12 단계, 이미지 1/2 Sharp Aquos LC13B2UA Front Case Replacement, Front Case: 12 단계, 이미지 2/2
    • Remove the eight 10mm screws connecting the two speakers to the front case.
  13. Sharp Aquos LC13B2UA Front Case Replacement: 13 단계, 이미지 1/3 Sharp Aquos LC13B2UA Front Case Replacement: 13 단계, 이미지 2/3 Sharp Aquos LC13B2UA Front Case Replacement: 13 단계, 이미지 3/3
    • Remove the two black tape strips securing the audio cables to the case.
    • Lift the audio cable from the plastic prongs securing it to the front case
    • The speakers can now be removed.
  14. Sharp Aquos LC13B2UA Front Case Replacement: 14 단계, 이미지 1/3 Sharp Aquos LC13B2UA Front Case Replacement: 14 단계, 이미지 2/3 Sharp Aquos LC13B2UA Front Case Replacement: 14 단계, 이미지 3/3
    • To remove the LED circuit at the base of the front casing, unscrew the two 5mm Phillips screws.
    • Lift the circuit to remove the plastic LED casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Robert Hobson
회원 가입일: 01/20/11
1,290 평판
안내서 9개 작성하였습니다
Cal Poly, Team 1-11, Amido Winter 2011 Cal Poly, Team 1-11, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G11
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 2,806
