주요 콘텐츠로 건너뛰기
Sharp Aquos LC13B2UA Fuses Replacement
필요한 것
  1. Sharp Aquos LC13B2UA Fuses Replacement, Stand: 1 단계, 이미지 1/2 Sharp Aquos LC13B2UA Fuses Replacement, Stand: 1 단계, 이미지 2/2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA Fuses Replacement: 2 단계, 이미지 1/2 Sharp Aquos LC13B2UA Fuses Replacement: 2 단계, 이미지 2/2
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA Fuses Replacement, Back Case: 3 단계, 이미지 1/3 Sharp Aquos LC13B2UA Fuses Replacement, Back Case: 3 단계, 이미지 2/3 Sharp Aquos LC13B2UA Fuses Replacement, Back Case: 3 단계, 이미지 3/3
    • Remove the two back panels by prying them out with your hands.
  4. Sharp Aquos LC13B2UA Fuses Replacement: 4 단계, 이미지 1/2 Sharp Aquos LC13B2UA Fuses Replacement: 4 단계, 이미지 2/2
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Sharp Aquos LC13B2UA Fuses Replacement: 5 단계, 이미지 1/1
    • Using your hands, gently lift and remove the back case of the television.
  6. Sharp Aquos LC13B2UA Fuses Replacement, Fuses: 6 단계, 이미지 1/2 Sharp Aquos LC13B2UA Fuses Replacement, Fuses: 6 단계, 이미지 2/2
    • To identify a broken fuse, look at the thin wire running through the center of the fuse. If the wire is misshapen or broken, the fuse needs to be replaced.
    • To remove the fuse, either push from one side or pry gently with a spudger.
    • Make sure to replace the fuse with the correct amperage and voltage fuse. The correct voltage and amperage is displayed on the side of the fuse.
결론
Robert Hobson
회원 가입일: 01/20/11
1,290 평판
안내서 9개 작성하였습니다
Cal Poly, Team 1-11, Amido Winter 2011 Cal Poly, Team 1-11, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G11
4 회원들
안내서 9개 작성하였습니다
댓글 한 개
I recently replaced a blown fuse on this model TV. When testing it with the back still off, the power light turned red, then green, then went off. Puzzling. It turned out that the back has to be on the TV and the screws have to be in (at least, the screws that make contact with metal parts). After that, all good.
atbatcat - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 11,801
