주요 콘텐츠로 건너뛰기
Sharp Aquos LC13B2UA Motherboard Replacement
필요한 것
  1. Sharp Aquos LC13B2UA Motherboard Replacement, Stand: 1 단계, 이미지 1/2 Sharp Aquos LC13B2UA Motherboard Replacement, Stand: 1 단계, 이미지 2/2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA Motherboard Replacement: 2 단계, 이미지 1/2 Sharp Aquos LC13B2UA Motherboard Replacement: 2 단계, 이미지 2/2
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA Motherboard Replacement, Back Case: 3 단계, 이미지 1/3 Sharp Aquos LC13B2UA Motherboard Replacement, Back Case: 3 단계, 이미지 2/3 Sharp Aquos LC13B2UA Motherboard Replacement, Back Case: 3 단계, 이미지 3/3
    • Remove the two back panels by prying them out with your hands.
  4. Sharp Aquos LC13B2UA Motherboard Replacement: 4 단계, 이미지 1/2 Sharp Aquos LC13B2UA Motherboard Replacement: 4 단계, 이미지 2/2
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Sharp Aquos LC13B2UA Motherboard Replacement: 5 단계, 이미지 1/1
    • Using your hands, gently lift and remove the back case of the television.
  6. Sharp Aquos LC13B2UA Motherboard Replacement, Motherboard: 6 단계, 이미지 1/3 Sharp Aquos LC13B2UA Motherboard Replacement, Motherboard: 6 단계, 이미지 2/3 Sharp Aquos LC13B2UA Motherboard Replacement, Motherboard: 6 단계, 이미지 3/3
    • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  7. Sharp Aquos LC13B2UA Motherboard Replacement: 7 단계, 이미지 1/2 Sharp Aquos LC13B2UA Motherboard Replacement: 7 단계, 이미지 2/2
    • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
    • Remove the green/gray to orange/gray connector from the center of the circuit board.
  8. Sharp Aquos LC13B2UA Motherboard Replacement: 8 단계, 이미지 1/2 Sharp Aquos LC13B2UA Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  9. Sharp Aquos LC13B2UA Motherboard Replacement: 9 단계, 이미지 1/1
    • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Robert Hobson
회원 가입일: 01/20/11
1,290 평판
안내서 9개 작성하였습니다
Cal Poly, Team 1-11, Amido Winter 2011 Cal Poly, Team 1-11, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G11
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 7,454
